Old 09-14-2017, 03:46 PM
bheinen74 bheinen74 is offline
Re: front axle replacements
Originally Posted by Jvan View Post
Does anyone have an excess junk axle that I could send them?
you could just go to autozone to get the junk one. it will look nice and good, but GUARANTEE it is junk.
For whomever this place is that s going to build a superior axle, they need to use Subaru boots. Aftermarket boots are like bread wrappers, Subaru boots are thick, tough and long lasting.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 09-14-2017, 08:09 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
OK silly question - What the heck is a "Level 5" axle .... how does one equate L5 Vs L4 Vs L3 etc
Old 09-24-2017, 08:08 PM
Jvan Jvan is offline
The different levels refers to the horsepower that the axle can handle w/lower numbers being for less horsepower and the higher the number the stronger the axle to handle the higher horsepower.
Old 10-09-2017, 12:14 PM
I decided to have Thedriveshaft shop build new axles for the SVX. The axles will be overkill for the SVX at level 5 but they are the same price as OEM axles. I bought a used OEM axle to send them for correct measurements so in the future they will have a OEM prototype sample and not cheap Chinese junk.
