My SVX starts up, goes briefly then stalls out .. fuel related?
Looking for advice on this..I'm guessing either I've got a badly blocked fuel filter, or it's time for a new fuel pump. After the car stalls it won't restart again until it sits for a while. Then it will start again and only go a bit. Has anyone run into this?
96 LSi - Hyper Blue, 5 Speed - Magnaflow - Murano take off wheels - 70K |
Re: My SVX starts up, goes briefly then stalls out .. fuel related?
I'd start with the fuel filter easy access and only about $20
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Does it idle rough before it dies or is it like if someone 'pulled the plug'? Have you checked your MAF?
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
Thanks for the input and suggestions. I started with replacing the fuel filter and the car started right up (sort of as usual) and ran. So I ruled out anything on the pump side. I let it idle a while then it shut down. Here's the root cause...it was a bad battery. I've never had a battery situation where it would start the car, then run, and then basically just drop down on the voltage enough that the car just quits. I will check the alternator as my next step in the process. Thanks for the help.
