Thread Tools | Display Modes |
Help!! I'm going to get hit by a semi truck!! Random stalling, stumbling idle
Update,
Decided to start a new thread as the old one is so long now it is time consuming to follow. Car is stumbling (intermittently) at any rpm below 4000. Will run smooth for approx 1-2 seconds then hit a wall dropping rpm by 200 or so. Occasionally causes stalling when at cruise on highway or at stop lights. SO, problem seems to only occur near idle circuit. Small throttle or zero throttle opening. Important note: It is not "surging" up and down like a boat in the ocean. Runs smooth, then hiccups, then smooth again somewhat rhythmically. Condition lets out a deep, airy poof at the muffler when the stumble occurs. Misfire? Backfire? Vacuum leak? Failing sensor? I can't figure this out. Had car at a local Subaru dealer twice who first replaced intake manifold gaskets first, and then the alternator second, (again.) Last time they suggested that I buy an entire new engine wiring harness based on the fact that the outer coating is cracked on one of the crank sensor wires. Whaaaa??? Decided to take this on myself now: Have not removed manifold yet. Trying things a little at a time. -Pulled intake snorkel and inspected. Sealed up any suspect intake leak. = no change -Pulled and cleaned Throttle body, not very dirty BTW. = no change -Pulled and cleaned By-Pass air valve, also not very dirty. = no change -Replaced small diameter vacuum hoses on top of TB to metal tubes near TPS = no change -Replaced vacuum line between what I believe is the fuel pressure regulator (just above EGR valve) and the intake manifold = no change -DVOM test on By-pass air = good -DVOM test on Mass air, both key-on, and engine running conditions, even tapped on it hard and wiggled wires = good. -DVOM test on knock sensors = good -DVOM test on injectors = good -DVOM test on pass side coils = good. Although when I removed the boots, the part attached to the coils, (not the plugs) had little white lightning bolt streaks on the inside. Cleaned off and re-installed. Have not pulled the driver side yet. Have sprayed starting fluid, propane, MAF cleaner on all suspect vac leak areas with no change in idle. Arrgghhh. After reassembly, running engine in garage: Idle would not fall below 900 rpm no matter how hot, no matter how many times the fans cycled, no matter how many times I revved it at the TB. Running Defroster kicked it up to 1100-1200 rpm. Have not road tested yet, I don't like the idea of getting hit if it stalls again. Still hearing a strange clicking chatter (pretty loud) from under the manifold when throttle is blipped and is returning to idle. Almost like the IAC valve is chattering or a solenoid is freaking out. Only occurs UNTIL car is completely warm. Hearing a hissing type of noise coming from area around power steering pump/reservoir. The assembly is leaking fluid from somewhere (likely from re-using the o-ring under the reservoir when the timing belt was changed by a tech recently). Could also be the bearing going out on the PS pump shaft. Hard to tell. OR this could be my vacuum leak somewhere around this area. I still question a burnt catalytic converter or O2 sensor that is not throwing a code. I had a thought to take the car to a muffler shop and by-pass the cats and fab up heat shields, (there are no emissions checks in MI) to help rule them out. Any help is greatly appreciated.
Mac __________________________________ 1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and ..... 1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs Last edited by macadamianut; 03-03-2010 at 07:11 PM. |
Re: Help!! I'm going to get hit by a semi truck!! Random stalling, stumbling idle
I guess you are the one who Todd told me about... PM me your address and I will send out my loaner set of position sensors.. I have had intermittent sensor failures that would not result in error codes but similar drivability issues
As for the click, the EGR sol, IRIS sol. and evap sol. are all mounted under the manifold. If it is clicking and not throwing a code, it is working as it should be Tom |
Didnt you say you were running a different ECU too Mac? Did you try putting the stock one back in to see if anything changes? |
When you cleaned it off them, did you put any silicone spray or such on them. I think you should make a 'garden hose stethoscope' and go hunting for the 'hissing' and the 'clicking.' Finding what these are, may point you in the right direction. Harvey.
Tom,
Yes please!! Loaner sensors to isolate would be most helpful. PM sent with address. Thanks. Chris/Harvey, Modifications on car: -ECU tune 1v5, octane switch NOT installed, no stock ECU to swap out -Stebro muffler -Perrin lightweight crank pulley -One pair Hella 500 off-road lights -Mudflaps - darn, I bet it is coming from the mudflaps Another possibly important point of interest- Oil fillneck gasket, valve cover, or both are leaking on the driver's side near the battery. It has coated the cam pos. sensor area and will look tonight if it is causing problems with my coils on that side. If anyone has an extra unmolested OBDI ECU they could loan for a try that would be most appreciated too. I will re-pull all plugs and coils tonight and inspect the boots for more shorting. Little tiny white tracks of lightning bolts inside the boots last time. Will spray with silicone this time. May still pull off the manifold and inspect/clean all the bits underneath. Thanks for hanging-in here with me, I can't tell you guys how much I have learned about my car and working on cars in general so far.
Mac __________________________________ 1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and ..... 1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs Last edited by macadamianut; 03-04-2010 at 07:13 AM. |
Mac, If you are pulling your intake manifold, I HIGHLY recommend replacing the PCV Valve, PCV Hose (molded hose, available from the dealer for ~$15) , IRIS check valve, and associated small diameter vacuum lines (you can use universal vacuum tubing and cut it to fit). Pulling the manifold presents an excellent opportunity to address all of these items, all which are very inexpensive, and a PITA to address when the manifold is on. Just my $.02.
1991 SVX L JDM |
Mike,
I will be replacing all associated vac lines and PCV line under the manifold. My PCV, fuel filter, timing belt and spark plugs (bosch iridium/platinum) were changed about 3,000 miles ago. Replaced IRIS check valve last weekend. Also removed K&N, cleaned MAF and went back to OEM paper type. Does anyone know the DVOM specs for the egr solenoid and IRIS stuff under the manifold? I don't remember seeing it in the manuals. My DVOM tests on the coils has just been that they are all equal resistance. Does anyone have the correct specs to check primary and secondary on the coils? Thanks.
Mac __________________________________ 1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and ..... 1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs |
I will have one on my way back from my trip on the 14th if you don't figure your problem out or get one in the meantime. Hopefully you get it all sorted by then though
A random thought. The IAC (not by-pass air or auxillary air) controls the idle/off idle mixture and is driven by a solenoid of sorts right?
If that valve were to get stuck, it would screw up my mixture and cause stumbling problems? I hear that strange loud clicking coming from under the manifold, so is it possible that that valve is stuck and I am hearing the solenoid freaking out from not be able to move it? Is it supposed to be open at idle or closed? When I remove it from the manifold tonight, is it supposed to be open or shut?
yes/no. The IAC is a dual action motor voltage in to open and voltage in to close. The MAF is what calculates the airflow regarldess of this. So if the ECU sees the valve is stuck due to an uncontrollable idle it will use a fuel cut (very noticeable) to stall the engine speed down. If this were happening, you would def. know it and there would be a trouble code active for it
Tom |
