Old 03-07-2009, 01:39 AM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
? For those with aftermarket soundsystems
I just installed a new head unit and wired my car for a sub and amp. However, I'm not gettibg any power to my amp. All of my connections are solid and the fuses are all good, so the only thing I can think of is that my ground isn't good. Where is the best place to connect a ground wire?
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 03-07-2009, 02:04 AM
Re: ? For those with aftermarket soundsystems
A lot of work but I always ground back to the battery. A lot of car audio people say it is bad for different reasons but In every car I've had, it has eliminated dimming headlights even in an 81 olds with only a 65amp alternator(1000+watt system) and have never had problems with voltage noise caused by a supposed ground loop that they claim is what happens if you ground an amp back to the stereo.
Other wise, find a factory grounding spot or sand off all paint on a spot in the trunk and tap into the trunk-BE SURE TO BE AWARE OF ANY POSSIBLE WIRES AND USE A SHORT SCREW!!!
Edit: And just to note, I've grounded back to the battery in 5 separate cars and have a friend that competes in comps who also always grounds back to the battery. Capacitors and extra batteries are actually not a good idea as they put extra load on the alternator. Extra batteries only help when listening to stereo with the motor off when its parked. I have never seen capacitors help a stereo sytem in my life.
Old 03-07-2009, 06:23 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I unbolted my trunk latch and fed the wire into an eye connector, then reattached the bolt back to the trunk latch. Mine has worked fine for years.
+1 on not using a capacitor/2nd battery. If anything you should be upgrading the alternator wiring.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-07-2009, 06:27 AM
Thats another good idea I forgot to mention-any existing bolt that already bolts to the car
Old 03-07-2009, 06:28 AM
Tim's Avatar
Tim Tim is offline
The less drilling the better.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-07-2009, 06:52 AM
Earthworm's Avatar
Meow!
Where did you have your ground connected?
Can you confirm all your connections with a volt/ohm meter?
Are you getting a voltage on the signal wire going to the amp from the head unit?
Old 03-07-2009, 08:41 AM
AyeJaye's Avatar
I checked it this morning with a basic test light, and I'm not getting any juice from the primary power lead at the amp, so I'm assuming it has to be the ground. I found a place under the flap that covers the gap between the back seat and the trunk floor, but apparently its not a solid ground. I have to work today, but I should have a chance after work to do some searching and find a better place to mount it.
Old 03-07-2009, 09:12 AM
redlightningsvx's Avatar
Collision Refinishing Tech
I grounded mine on the back seat bolt.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-07-2009, 09:42 AM
AFBeefcake's Avatar
Subaru Swapper
Mine is grounded to the trunk latch mounting bolt, under the plastic trim piece that runs along the rear of the trunk floor.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-07-2009, 12:12 PM
Earthworm's Avatar
Meow!
... I'm not getting any juice from the primary power lead at the amp, so I'm assuming it has to be the ground.
I must be reading this wrong...You're not getting +12V to your amp so the ground is bad??
Checklist:
- check for ~12v on cable going to the amp
- check ground cable for continuity to a separate ground
- check signal cable for 12v with head unit on
If these are all good perhaps there's a problem with the amp or a fuse is blown on the amp.
Old 03-07-2009, 04:11 PM
AyeJaye's Avatar
I figured it out. Turns out the screw I originally used screwed into a plastic clip, which obviously ensured that I didn't get a solid ground. I made a new hole in a metal panel and now my trunk goes boom (it was dark when I did the original wiring job so I missed the plastic part the first time around)
