Rear Bearings
Monday morning I will be replacing front CV axles. rotors and pads...and then rear wheel bearings......Any one have the latest torque values on the axle nuts and /or tightening sequence or setting the load? Going to check tie rod ends while I'm there and probably remove the rattly assed heat shields.
Re: Rear Bearings
I don't know how to make a link but look this up:
-Technical Q&A -Torque specs for rear housing -Post #4
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Re: Rear Bearings
Cool....found it..I read where you did your rear bearings,,,on a scale from 1-10 how much of a bych and how long for both sides?
Re: Rear Bearings
I dropped the rear diff to get the axles out (done four times, so it's easy )... the long bolt for the lower arms was so rusty it would have broken had I tried it.
To get the old outer races out I used an unorthodox method of gently welding a beam (MIG) around both ball runs to contract the race... you can push it out with very little force. I made a threaded tool to press frozen new races in. The rest is easy. Tapani |
Re: Rear Bearings
Per Nate's advice, I also replaced the hub the last time I did the bearings. I think that is very good advice.
Re: Rear Bearings
Be prepared for nuts and bolts to be seized and destroyed during removal process and getting to the rear housing. Have new nuts and bolts on hanf BEFORE attempting this job..
Ive just replaced every component on the rear suspension to include bearings so all my troubles and mistakes are fresh in my mind |
Re: Rear Bearings
Well, truth is, I don't know how long it's been going on and attributed it to the CV axles which have been clicking over a year.I know for a fact the tranny fluid hasn't been changed in 60k miles.
Re: Rear Bearings
I use Redline but my tranny has been serviced regularly, the fluid is pristine and I have no evidence of parts being laquered. If your seals are coated and dried out and you use a synthetic like Redline, you can get lots of leaks. For your case, I would avoid such fluids and stick with the basic Subaru supplied stuff.
Re: Rear Bearings
Well, all the rear bolts came out with no issues. (rust really isn't an issue here) Front axles are in and had the bearings pressed in this afternoon...Tomorrow,,, she comes back together!Thanks dannmarr for the pics and torques!! uber helpful!! tHEY SHOULD "STICKY" THAT POST.
Re: Rear Bearings
Great to hear it worked out for you!
Re: Rear Bearings
Alrighttttt......she rolls quietly,, no more "click click click" but i still have a binding in slow turns and if i turn tight enuff up a small incline,,it wont make it without "help". That being said..If i goose it a tad at "stop" I can hear something in the neighborhood of a bound "grind?? squeak?? If read posts about solenoid C or possibly some LSD??
Re: Rear Bearings
Just did the 10 amp fuse in the FWD slot and the binding goes away...tranny flush with LSD?
Re: Rear Bearings
This has nothing to do with the LSD. Also, you can't flush the LSD. The LSD is a sealed unit. Someone should pop in to advise you on how to free up the transfer clutch unit.
'92 SVX LS Pearl White - 6mt |
