Hub Rings info w/ Pics
For anyone buying aftermarket rims, make sure they offer
you Hubrings, one for each wheel. The make the rim fit snug against the factory hubcenter. Pic one: the actual ring...
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
step 2
this is usually what the back of the new rim '
looks like.....
step 3
Pop the ring in the back of the rim
(it goes on only one way...)
OR
you can put the ring directly on the Hub like this....
pic one...... This is before.....
Installed
this is what it looks like installed on the Hub....
Bolt on your wheel, and your done..... Mostly youll want these to prevent unwanted vibration transmitted from the wheels thru the cars suspension and chassis.....
thanks Dayle
do they fit all wheels.
I don't think I have them on my rims
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
Do all aftermarket rims need them?
Aftermarket rims that do not have the exact centerbore as the svx rim need them to properly center the tire on the hub. They are made specifically to fit the inside of the aftermarket rim and the hub on the car.
its like this
90% of the rims on the market now a days wont come
hubcentric specific for your car.. for example, its much easier to make the centerhole in the New wheel larger then what all cars need, and then offer hubcenter rings specific for your vehicle This way they get have their rims properly fit just about any application. There are only about 8 different size center bores used on most cars out there, luckily the SVX is a 56.1 bore and thats the same as alot of Nissans and other cars on the market. If you dont have the rings, I suggest contacting the place you bought the rims from and see if they have them for you. If not, have them contact the manufacturer of the rims and for about $10 or less they will usually send you a set of 4. Keep in mind, all centerbores of the Rims can also be different, so its important your center ring fits tightly in the Rim just like it will on the hub. Just about all wheel manufactures out there offer these rings, so check it out. Sometimes the rings are plastic, some more hi tech companys make their rings out of aluminum.
available, I suggest getting some if you dont have them and you have any vibration problems at any speed..... Some people will think its wheel balancing causing the problem when it could just be solved by a set of rings.....
well I got focal F-5 rims do you know what size rings I need?
depends on the rim
Depends on the size of the hole in the rim.....not sure on Focals. The inner diameter has to be 56.1 mm not sure what Focals size Focals use for the outter diameter. If you contact a Focal dealer in your area, they should be able to tell you.......
re: thanks
thanks dayle
