Re: Common things to go out on an eg33
The front diff's seem to be a bit fragile.
Um... since when is the front diff part of the eg33?
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
He is probably just Confused, Chris.
I would replace the Temp sensor, all the timing sensors, two crank, one cam sensor, PCV valve. These give the most common problems. Harvey.
dont forget knock sensors! those are the most common failure point of these engines
Harvey.....I would replace the Temp sensor, all the timing sensors, two crank, one cam sensor, PCV valve. These give the most common problems.
Sube Fan... dont forget knock sensors! those are the most common failure point of these engines Kwren...throw in some temperature sensors... Must not leave out the "yourconfused" front diff thingy! Those little items will probably get us up to a few thousand dollars? Maybe just drive it if it runs Keith Last edited by kwren; 12-27-2008 at 04:34 PM. |
Go ahead and reseal it before you toss it in save you some headache later due to leaking cam seals etc.
How many miles are on the engines? If I were you, I'd replace the headgaskets while the engine is out. There have been more than a few that have failed most likely due to age. They have tended to fail and vent pressure to the cooling system.
Your comment on coil issues can be attributed to ham-fisted owners and techs tearing the wires and boots when removing them prior to replacing the plugs or cam cover gaskets. Take your time and the boot can be peeled from the plug body. Also, replace the cam drive belts and check the idlers when you have it open. When in the front of the motor replace the front end seals and o-rings.
Down to none |
