what flywheel to use for 6spd swap?
just wondering would the 6speed flywheel and clutch etc bolt on to an EG33? or do you have to use 5speed clutch and flywheel up to the 6spd and EG33?
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
Re: what flywheel to use for 6spd swap?
you can use the 5mt clutch and flywheel for a 6mt but your disk area is smaller and has less clamping force.
Personally I use stock flywheels as I don't like lightened ones... but thats just me Tom |
sweet i was just wondering bout that. had some one advertising an light weight 5speed flywheel and said it can fit to both. just wanted to make sure.
why arnt you kean on using light weight flywheel?
Perhaps because light flywheel will dampen the "feeling/sensing" while shifting due to our heavy cars?
Tom, you also went back to stock clutch right? Or are you still using the six-puck? -Sov
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd |
still using the 6-puck
I don't like lightened flywheels because reducing the rotating mass of the flywheel can actually change the characteristics of the engine and enhance the "mt stall" due to its ability to not only speed up faster(w/o load) but slow down faster as well. That and I trust my beefy flywheel spinning at 7000rpm not some piece of aluminum Tom |
Talk about a fun car to drive. Definitely the hardest car to drive
I think a heavier car like an SVX really needs a flywheel with some heft. Low inertia makes starting from a standstill a bi*ch with a heavy car. Makes the day-to-day stop and go traffic very unpleasant. On Jack's Impreza with the EG33, a lightweight WRX chromoly 5-speed flywheel works fine. But that car weighs +/- 2800 lbs and has 4.11 gears. And you seldom do standing starts while road racing. |
