Diagnostic code:Air control valve 24
ran diagnotics on my car came up with code 24, not familiar with the air control valve. any other possible things this could be such as dirty air filter, how would i correct this?
"wow how much money did it cost for you to do that to your windows, thats some pretty custom $h!t" |
no idle problem, it starts idling at 1200 for about 15-20 secs then drops down to 750-500, no stalling, where is this valve located and is there a sensor or something i could replace
how do i reset the ecu, im going to buy a new air filter and clean out the throttle body, then run the codes again. good idea (y/n?)
thanks
Reset the ECU using the process in the SVXipedia:
http://svx-iw.com/ -> SVXipedia -->Checking Error Codes --->How to Check Engine (ECU) Trouble Codes
