Old 05-29-2011, 08:51 PM
Rims that fit
i checked the ?search but didn't find the info I need . I see a set of wheels for sale 17 " 114.3 5 bolt ... That seems fine offset 40 that seems Ok BUT she said that the bore ( hole in center I guess ) is 73 mil. and there is a cap that covers the nuts what is the axle dia. and how far out does the axle stick out? anyone use this type of a wheel ?
4 Hankook Tires 215/45r17 87H Radial K106 & Rims ALT 17" G-Force , SIZE: 17x7
Also 1 additional Rim minor damage, (dime size damage)
Old 05-30-2011, 12:55 AM
XT6Wagon XT6Wagon is offline
Re: Rims that fit
Easiest way to ensure they fit is to order rims (and lugs) for a 2005 STi. Same bolt pattern and offset tolerance as the SVX. Oh and STi sized tires are a little larger than stock but still work so you can just keep the tire person ignorant of things that stress thier mind... like rims from one car can fit another.
Offset 40 *might* work with a narrow rim like you are asking, but you really need to stick to the 48-55 offset range for best results.
Old 05-30-2011, 06:07 AM
Re: Rims that fit
Looking at Used rims & tires . I am not sure but can find out what they came off of ..
Old 05-30-2011, 04:11 PM
Re: Rims that fit
Might be mustang. Not sure what the Honda/Acura offsets are.
Old 05-30-2011, 04:41 PM
92 SVX 92 SVX is offline
Re: Rims that fit
I believe newer honda's use 5x114.3 with +45 offset, it will technically work I seen someone put them on there svx but the rim might be too narrow for a good fit.
I think some of the older 5 bolt honda's used 5x100 so that would not work.
And most of the honda's are going to be 4bolt.
You can run many of the 5x114.3, or even gm's 5x115 rims the problem you will have is 1. Rubbing the fender if the offset is too low IE a +30 such as some Nissan Z rims. Also depending on how wide you may find a tire rubbing on the inside not the outside. Then and probably the worst thing about running the wrong offset. The stress put on your wheel bearings will cause them to fail prematurely.
This will depend on your diameter, width, and offset though. If I dont have this backwards a 18" rim with a +42 offset that is 8" wide would keep the bearing happy just as if it was stock 16" rim +55 offset 7.5 wide rim.
Old 05-30-2011, 06:19 PM
Re: Rims that fit
What about the center hole dia. I am going to try them out on the car. said they are 40 offset 5 hole 114.5 with a 75 mill center hole . What about the center sticking out? These have a cap over the bolts.
