Engine block plastic parts (p/n required)
I am looking for the plastic pieces that locate on the block and hold in place the HT leads down the length of the block, mine are shot & 1 is missing.
Each have "C" shapes in order that the HT leads slide & get held in place - side by side along block length. Each plastic piece has 2 location pins, that clip into the block. The ones between 1 & 3 / 2 & 4 mount flush to the block. The ones that are at side/rear behind 5 & 6 have a bevel in order to aid with directing the HT leads from the side to the rear of motor. Part numbers & availability would be great to know - my part manuals are currently boxed in a storage unit. Thanks Steve (in New Zealand)
Re: Engine block plastic parts (p/n required)
ignore the previous post - I got the pieces from www.zebraupickcarparts.co.nz - there was a 92 that looked in really great shape - no rust that I could tell?.
When you say "HT" are you referring to the coil pack wires?
Opposed forces in addition to the factory manuals are a great resource for part numbers.
http://opposedforces.com/parts/svx/
Yes sorry that is what I meant = coil pack wires.
Would still like to know p/n.. TIA
Although I am not much help, I too would like the p/n's. I installed all new coil packs and through the purchase process was unable to find the coil pack wire place holders. Perhaps they are only available in the engine seal kit?
