Manual Transmission Replacement
Hello all,
So after having fun times in the 5spd it appears my trans no longer likes 2nd gear. See the video below. What options are out there for direct replacement. I have the 3.90 5spd so if I have to go with a different gear ratio I can. Also it is a cable so hydraulic is out. Now is it possible to have hydraulic converted to cable? If so there are many cheaper options than attempting to find a direct replacement for what I have. I do not want to have to install the necessary stuff for hydraulic operation. What transmissions can I get to replace my 5spd Cable 3.90 trans? Or should I just seek having a rebuild (minus removal / install labor as I'll do that myself). Thanks
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Re: Manual Transmission Replacement
you can use a NA Hydraulic Transmission, as they can be swapped to Cable, you just can't use a Turbo Transmission with a cable.
Hard to tell from the video. Are you skipping 2nd? Rebuilding a 5 speed is a lot easier than an auto. Heck I rebuilt my 3 speed Chevy tranny when I was 17 years old. It is all Mechanical. I would check with a tranny shop or a shop that u are Sure has done it before. Old school ( 55 year old ) could be a chipped gear, bent fork or bad Syncros
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Wow BITD you could replace everything one at a time. Sorry I forgot about improvements. I pulled my 56 Chevy one apart and removes the Syncros and the 2 nd and 3 gear. Go looking for a replacement tranny. My PO had 2 gears replaced in my tranny. .??
What about if I go with a different gear ratio? will the rear diff need to be messed with? Also I can find new Impreza / legacy / etc lower milage used for cheap. (2008ish). Anyone attempted to use a newer transmission ? (the non turbo hydraulic models).
2008+ Impreza transmissions you will have a problem with as the manual trans VSS were finally integrated into the ABS wheel speed sensors. (auto's started around 04ish) These transmissions have no VSS port on the trans and will not be able to work with an SVX. You can use hydraulic non turbo transmissions by simply swapping over the fork and few other bits from your current trans in the car.
And yes, you'll have to mess around with the rear to swap the LSD over if you change gear ratios. |
Sounds like you got an easy out...
Benefit of living in Subaru land.
Ended up with an 07 transmission. I am pulling to engine and transmission in one go. Going to replace the head gaskets, valve cover gaskets, check the timing belt and rear main seal.
Anyone have any other suggestions while its out?
That sounds like a broken or chipped gear tooth.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
Probably. I will find out more when I break it open.
Thread Tools | |
Display Modes | |
