Old 12-11-2013, 06:14 PM
Gamesy's Avatar
Gamesy Gamesy is offline
svx lsd in other subarus?
can the svx lsd be used on other subarus? i recall that people swapped it when they did the 5spd swap. but can it be done on a regular wrx or legacy? and do you need the svx rear diff axle stubs?
Old 12-11-2013, 07:04 PM
Re: svx lsd in other subarus?
I believe the gear ratio is unique to the SVX.
Old 12-11-2013, 08:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
3.54 and bring your axles
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-12-2013, 04:40 AM
Gamesy's Avatar
but i thought for the 4.44 swap people swapped the lsd from the svx diff into the new diff
Old 12-12-2013, 05:23 AM
Yes, you can swap the LSD unit into another diff and use the other diffs ring and pinion to do gear swaps....but no other Subaru came with the same style LSD and axles as the SVX, hence the need to preform such swaps to change gears...
