Scratching my head with this wheel bearing
Tom and Nate both confirmed that what I thought was a wheel bearing going was likely just that. It was definitely a lot louder when we arrrived in Reading from the drive from NY. About mid-way home I thought it started to sound quieter. I figured maybe my ears were just adjusting to the noise and drowning it out. But this morning, on the way to work, it DEFINITELY was quieter. I could still hear the same noise but it was pretty faint as opposed to quite loud on Saturday. Can wheel bearings do that or is this a clue or symptom of something else/more?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Scratching my head with this wheel bearing
Your bearing could have shifted or the one needle that was stuck could have destroyed itself. The bearing is still shot. And before I get flamed on this let me tell you I know a lot more about bearings than most of you do. I built , designed, and R&D for Ingersol Rand and Timken for 38 years. I ate and slept bearings.
I had a bearing replaced three times before I changed the entire hub assembly (housing included). I have not had a bearing problem since then. That was a few years ago.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 05-01-2012 at 02:50 PM. |
That hub is the inner race. Too bad Mother Subaru didn't design it so it had a removable inner race. That hub has to be spotless and polished smooth. One scratch or nick and it will destroy the bearing. TIMKEN makes a good bearing.
Are you sure? Makes no sense... Keith |
Sorry to rerail the thread
I just ordered rear bearings and seals from Chaplin but wonder if I should order new hubs too. The car is going to the doctor's who will replace brakes and bearings and hopefully rear brakelines as well. They estimated 1.5 hrs work per side for the bearings. Should I just order new hubs (I can't see they were ever replaced) and how much labour will this add on top of the bearing replacement? The cost of a hub is nearly the same as one work hour If you think it's a good idea to replace the hubs, which parts do I need except for the hub itself?
I got my girl, I got my glass, I got my car and I'm ready to f... |
From what everyone says, the hub spindle is what the bearing is riding on. I would have to look in my service manual . If that is not the case than the condition of the hub ( I am still assuming spindle ) would make little or no difference. The surface you speak of, is that in direct contact with the BALLS . I have never seen this apart. I just referee to my manual. Bearing has an inner race and it is balls ( full compliment ) meaning cageless at least it looks that way. The hub spindle is pressed into the inner race. Looking at it , other than the cost of a new spindle labor/ cost to install should be the same .
problem with the hub is that the inner bearing race is pressed onto it and if the race spins or gets too hot from a bad bearing it will destroy the surface of the hub. seems to happen on a lot of subarus, i usually estimate hub replacement when i replace a subaru wheel bearing.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Anyone got a part number for a rear left (driver) hub?
And the right? And if/which parts are needed in addition to the hub in order to replace it properly?
Thanks
I assume it's 28052PA010 but don't kill me if it isn't!
And remember axle nuts.
I am going to assume the hub is toast as this is at least the second bearing to fail in it. However, this bearing may have fallen ill due to another issue I uncovered while doing some research. IF the mechanic said, "pffft, I'm not going to clean out the old grease as it is usually a non issue to just re-pack with new grease", there could have been grease incompatibility issues. It is true that this is normally not an issue. Bearings come packed with grease that is mineral oil based with a Lithium soap thickener. It isn't great quality stuff and there probably isn't enough of it in there but it is compatible with most other greases.
Page 39 of the following document has some compatibility charts: http://www.fis-services.de/gen/en/do...n_WL81115E.pdf And this link has another, more extensive, chart for thickener compatibility: http://www.mindconnection.com/librar...easecompat.htm I have asked Timken what their stock grease is and I am waiting to hear back from them. It is most likely Lithium soap in mineral oil. Do you know Conn SVX? I can tell you that Mobil 1 is Lithium complex soap in PAO oil. PAO is compatible with mineral oil and Lithium complex soap is compatible with Lithium soap. So no problems just adding M1 grease with the grease that is already on the bearing. My situation is that I used Redline CV-2 grease. The grease has insanely good specifications but I have found out that it is a Calcium Sulfonate thickener in an ester base oil. Ester oil is compatible with mineral oil but Calcium Sulfonate is only borderline compatible with Lithium soap. Whether that was the cause, or a bad hub, I am going to replace the hub and use M1 grease. If I could be certain that all of the original grease was cleaned off and the bearings were free of solvent, the Redline grease would be great: http://www.redlineoil.com.au/Uploads...e%20doc001.doc Compare to Mobil 1's already good specifications: http://www.mobil.com/USA-English/Lub...ic_Grease.aspx
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 05-01-2012 at 10:26 AM. |
