A/C condense water outlet clogged?
After using the A/C and switching to ECON it gets damp inside. How will I know, if the condense water outlet is clogged?
Re: A/C condense water outlet clogged?
most likely the evaporator case drain is clogged. the evaporator is the part that is inside the car. if you look outside the car on the opposite side of the firewall from where the evaporator is you should see a small tube coming out where the water would normally drain.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
I guess, blowing air through the tube might cure the problem.
you might want to poke something in there to clean it out such as a pipe cleaner or heavy guitar string. if you blow air into it then all the debris will be pushed inside and eventually end up back where it was.
Keith |
Thread Tools | |
Display Modes | |
