Old 01-27-2009, 05:22 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Question FWD 5spd swap
well as it turns out my 94 L went through it's second transmission
and although i've been trying to get a rebuilt one, the price is...well a little crazy
so, i looked at the kit from smallcar and it's cheaper then the 4EAT and it got me thinking....ive wanted to do a 5spd swap so why not now, however, im only FWD and im not sure if that kit would work.
i called and asked and the owner (im guessing) and he said that all they have to do is cap off the rear where the rear driveshaft comes out....is that a safe move? would there be any problems?
any help would be greatful
p.s. has anyone had any trouble with that company's transmission?
Old 01-27-2009, 05:38 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Re: FWD 5spd swap
Unless you have a real desire to stay FWD, swapping to an AWD 5MT should be just about as much work as swapping to a FWD 5MT. All you have to do is swap in the rear diff, drive shaft and rear axles, IIRC. Which, in the grand scheme of doing a 5MT swap to begin with, isn't all that much more work.
Someone correct me if I'm wrong... I've never been under a FWD SVX.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 01-27-2009, 06:35 PM
Re: FWD 5spd swap
Entire rear subframe needs to be switched out... But after that its just diff, axles, and driveshaft
FWD on the right, AWD on the left
