Old 01-18-2009, 11:58 AM
SVX Maxximus SVX Maxximus is offline
Jordan
AWD not working!
I live in Iowa and have spent my winters enjoying the drifting in the snow. As of a couple of months ago my AWD has seemed to fowl up. It works like a FWD car now, and the front wheels will spin like crazy just as a FWD car would in snow. Only at high RPM will the rear wheels engage, and that is a bummer for safe driving... and drifting I have checked the transmission oil level and it is full, and suggestions? Is this typical of a failing transmision? Thanks much! Jordan Kjome
Old 01-18-2009, 01:14 PM
stuartracing stuartracing is offline
Re: AWD not working!
Did check you TCU for any code???? Just did mine and showing a 13 code....Shift sloinoid????You might find something...
P....
Old 01-18-2009, 01:55 PM
Your tranny is fine, it's the transfer clutch which may be in peril. If no codes are present that would be my guess
The transfer clutch and duty solenoid resposible for it's operation are in the transmission extension on the rear of the tranny.
Old 01-24-2009, 11:24 PM
robinhoodof she robinhoodof she is offline
I've got the same problem but no service light coming on, mine was sitting for four years before I got it, think it's just stuck...100 k on it. Is the duty solinoid IN the trany???(thinking it should be on the side) I climbed underneath mine & I see the tin heat shield, is it over top of it?
Last edited by robinhoodof she; 01-24-2009 at 11:28 PM. Reason: missed informatiom
Old 01-25-2009, 04:12 PM
You have a slow acting transfer clutch. This is either caused by a sticky transfer valve, or a slow rise in transfer clutch oil pressure, due to worn sealing rings on the clutch feed.
I would not continue to allow the front wheels to spin hard in the snow, before the rear engage. As it can cause the transfer clutch hub can shear off the transfer gear.
Old 02-23-2009, 12:28 PM
Jordan
So as the nearest Subaru service shop is hours away, would my local Goodyear Tire have the computer which could tell me of any faulty codes? Also, if it does turn out to be a bad transfer clutch or shift solenoid, how much do they cost? Does the engine/ transmission need to come out to put in a new transfer clutch? Thanks
Old 02-23-2009, 02:51 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
the only thing good year MIGHT be able to do is put in a new transmission.... you can check the codes your self... it is in the how to docs... eather way if it is the solenoid or the transfer clutch the transmission will need to be pulled so you might want to wait untill you have more serious transmission issues and take care of them all in one replacement
- John
Old 02-23-2009, 03:13 PM
NiftySVX NiftySVX is offline
It's your duty solenoid c. Trans doesn't have to be removed to get it out,only the extension housing. A good way to test it is to turn the car on, shift into any of the moving positions and you should hear the duty solenoid buzzing. It's hard to hear at first, but once you hear it, you'll know it. I use this method to diagnose a faulty solenoid all the time. If you hear a steady buzz (like a bee) then it's free and operating. Most likely you will hear yours buzz briefly when you first shift to R or a forward gear, then it will stop, or it won't at all.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
