Old 11-29-2004, 06:36 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
another best wrx track run
ran 12.80 @ 105 with a 1.85 60' time on pump gas and on low boost 16 psi
im gleaming abought it it almost ran a 12.70 11s are right around the corner for me and i cant waite
i beat out a camaro z28 ss that ran 13.30 and a new corvette that ran 13.00
this was all on pump gas stock cluch , stock injectors and stock intercool and only a piggy back fuel controler
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 11-29-2004, 07:27 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: another best wrx track run
That's awesome Solarsvx! I thought your clutch was pretty much shot? Did you get a new OE clutch or are you still using the old one?
You beat out a Camaro SS? Don't tell Shadow...he'll tell you the guy must have fallen asleep at the line as Camaro-Bird's are FASTAR!!!
-Chike
P.S. When you ran 15.4 on 107 octane in your former '92 SVX, what was the break down of your run? 60ft, 1/8th mile and trap speed?
2006 Steel Gray WRX TR (sold)
Old 11-29-2004, 07:40 AM
yes stock cluch still it decided to hold and i was launching at lower rpms around 5,000 rpm
my old svx runs do be honest i dont rember,, maybe 92 on the traps and i think 2.3 60' s im not to sure though, i wish i kept that damm time slip
i rember it was on a really cold night and i also learned whene i power braked the svx it ran slower times also
the camaro ss ran awsome, he just got breat , he did a 2.0 '60 wich is pretty damm good for RWD and he traped out at 105 also but also i ran a 13.3 with the stock turbo also =>
Old 11-29-2004, 07:28 PM
Chiketkd's Avatar
My best 1/4 mile run thus far in my SVX has been on a 58* night. Wish I could run it at the track when it was 45* or cooler though...
SVXfiles and myself have done a lot of testing with launches and our best times are consistently returned by power braking the car up to the 2500rpm stall and then flooring it. On a slower 15.33 run, I cut a 2.17 60ft time which is my best launch to date. If I launched from idle, my 60ft times would be in the 2.3-2.4 range which kills your final et.
Best of luck with the WRX. Glad your clutch is still holding up to the abuse...
-Chike
Old 11-29-2004, 10:06 PM
Shadow248 Shadow248 is offline
Rep from the outside world
Send a message via AIM to Shadow248
I heard that
The guy must have fallen asleep at the line as Camaro's are fastAR!!
Good run solar.
How come you only seem to race Camaro's? The last two runs you posted here happened to be against camaro's too. A 13.3 @ 105mph with a 2.0ft 60' is good for an average driver. Actually that is almost exactly the "average" f-body run.
Want to try a modded f-body? Let me know.
Old 11-29-2004, 10:18 PM
Chiketkd's Avatar
Originally posted by Shadow248
I heard that
Good run solar.
Your too funny Shadow!
On street tires, a 2.0 60ft was the best launch I could ever get with my SVT Lightning. I think the Camaro driver did a reasonably good job of lanching a rwd car with that much hp, but solar's awd launch was sweet which gave him the edge...
-Chike
Old 11-30-2004, 07:08 AM
shadow, just how i ran that night i dont pick the races i raced a 300zx and a few hondas but only ones put up a fight was the chevy's =>
and 2.0 60' is pretty decent not sure if he was on steet drags or not.
i wish i can start cuting 1.60 60' times without breaking anything would be nice, on stock street tires
shadow if u want i can scan the slip in for your veiwing pleasure
Old 11-30-2004, 09:48 AM
AHH...I see. I only found that strange because at the tracks near my area, I see a grand total of about 3 f-bodies per event...usually 1 is a good runner, the other two, beginners. Then I see about 25,000,000 modified stangs that can just barely hang with the stock f-bodies, evos, and sti's. So generally, I expect any given opponent to be a mustang.
Originally posted by solarsvxand 2.0 60' is pretty decent not sure if he was on steet drags or not.
I should have clarified...a 13.3 @ 105 is average on street tires, a bit slow for drag radials. If he was pulling a 2.0ft 60 on drag slicks he's got some learning to do. If an f-body driver can't get his car into high 12's with drag slicks, then he might as well find something else to do on saturday nights.
Don't bother. There's nothing outrageous about your claim.
Old 11-30-2004, 06:52 PM
Chiketkd's Avatar
What do 'factory' stock Camaro-birds run in the 1/4 on street tires? The ones I've seen run at the track which were lightly modifed (cams, intake and exhaust work) ran low 13's/ high 12's at best.
Thing is factory stock V8 Camaros and Firebirds only had 245 sized rubber (unlike the 275's on the SS and Firehawk). It's kinda hard to hook up that much torque off the line on such minimal rubber.
-Chike
Old 11-30-2004, 10:34 PM
I have no idea what an LSI F-body would run on 245's. I've never witnessed one run. Here is the generally accepted averages for 275's and slicks.
Goodyear F1 275 - 13.2 sec, 2.0-2.2 60'
Nitto 555R Drag Radials - 13.0 sec, 1.8-2.0 60'
Drag Slicks - 12.8 sec, 1.7-1.8 60'
That's for a bone stock car and a driver who knows his/her car.
Take the stock car on goodyears that runs 13.2 and put on a catback and aftermarket airlid and you'll drop 0.2 sec easily. Beyond that, it's anybody's guess. A well planned, "lightly" modded car (ex - Catback, long tubes, airlid, ported MAF and a 220-224 cam) should EASILY break into mid or even low 12's. Unless of course it was not tuned properly. Hell my cam is a 224 with only a 115 lsa and I should be running very low twelves or even high 11's when i hit the track this spring. Guys with "T-Rex" cams (230+ and 112-110 lsa) and stock heads are seeing mid to high 10's. Wouldn't want to drive those cars on the street though, or pay for gas.
Old 12-01-2004, 06:21 AM
ok enough thread hijacking !!!!! this thread is abought me me me !!!! LOL
thanks u 2 for the compliments and i will keep the svx world updated whene it breaks 11s
in the mean time whos going to let me use there svx !!!!
Old 12-01-2004, 09:45 AM
It wasn't me. I was framed.
Old 12-01-2004, 08:54 PM
Chiketkd's Avatar
Oh darn it. I'm just into drag racing. Sorry to have framed you Shadow...
-Chike
