Old 11-21-2004, 04:47 PM
Tycho
EG33 tear apart pictures for your enjoyment
http://homepage.mac.com/dgiessel/.Pictures/misc/eg33/
Old 11-21-2004, 05:12 PM
lee lee is offline
good stuff...hope I never have to see it in my viewfinder
Old 11-21-2004, 06:24 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tycho,
Great stuff! Very well documented. Were you just doing a straight rebuild, or something "special"?
Any chance you might be able to check out how much lift the engine can handle on the intake and exhaust valves before the engine becomes an "interference" design? A dial micrometer and a very light coil spring should do the trick.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-21-2004, 06:41 PM
nextse7en's Avatar
Graphic Artist
Looks like a fairly young engine - given the fact that the bore marks are still on the sleeve...
What are you up to?
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 11-21-2004, 07:29 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Very nice pics Tycho! Great tour of the 'insides' of an EG33...
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-21-2004, 07:41 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
awesome pics!!!! Is this a full blown engine rebuild ....maybe hardcore upgrades for boooost?
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 11-21-2004, 07:45 PM
deruvian
I'm wondering if he is putting the internals into those cardboard boxes for storage and organization, or for shipment...
Excellent bit of info. It is now on my computer for safe keeping.
Old 11-21-2004, 07:47 PM
Chiketkd's Avatar
Now that would be sweeeeeeet!
-Chike
Old 11-21-2004, 08:54 PM
THAWA
yes that is enjoyable
Peach
exposed
Best pictorial i've ever seen on the 33. Main brgs. look great...how many miles on block? All the hard core mechanics here appreciate the tear down.
Old 11-21-2004, 09:00 PM
Very impressive pics! What kind of camera are you using to get this quality?
Old 11-21-2004, 10:54 PM
Tycho
Parts are going in the box after being run through the parts washer for safe transportation back to my house.
I'll see about checking on the interferance lift values when I begin test fitting everything during the reassembly phase. Note that since you have hydro lifters you're still quite limited as far as cam options (hydro lifters and aggressive profiles don't place nice). I've run into this problem on my saturn and have begun a conversion for it using Kawasaki KZ1000 shim over buckets. From the "look" of things the EG33 has the same lifter diameter as the saturn (pre 99 LL0 motor) and could potentially use the same setup (the kawa pieces). This is someting else I will dig deeper into.
The direction of the rebuild is yet unknown...I have to make some decisions about that in the next couple weeks. Boost might come into the equation...but with a good rod ratio and short stroke...a high RPM NA combination with ITBs is not out of the question either (with the proper headwork to allow the motor to breathe).
No idea on milage...this engine had been swapped (and apparently in a fire also as much of the engine harness was fried tho the harness on the car was fine).
Camera is a Olympus C-750 Ultra Zoom.
Old 11-22-2004, 09:46 AM
SVXRide's Avatar
Cams
Tycho,
Probably not looking at anything too radical with the cams -- little better breathing (couple more mm of lift?) and a little more duration (maybe 10-15 degrees?). Thanks for checking into this during the build process.
-Bill
Old 11-22-2004, 11:00 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Wow...look at the hone on those cylinder bores. They look incredible, I wish there was a way to tell how many miles are on this one.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 11-22-2004, 01:48 PM
deruvian
Did you get the engine separate from the car? If not, get the VIN and do a Carfax check.
Not sure if Subaru did it on the SVX (or any car for that matter), but the VIN could be stamped on the engine block.
