Security remote....programming question.
I bought an aftermarket remote....I can not seem to get the car to go into programming mode so I can program the remote to the system.
Two different sources have given the following instructions for programming: 1) Turn security switch off. 2) Turn key switch on...then off, leaving key in switch. 3) Immediately turn security switch on....then off, repeatedly until the flashers go on and the horn beeps. 4) Then press the remote four times and the system should accept it. Doing all this and I can not get the car to get into the flasher/horn thing. Yet the security system works as it should otherwise. Am I doing something wrong? What if I disconnect/reconnect the battery and then try it. Dave |
Once into the programming mode, you will press the remote button slowly each time. .
when your security button is in the on position does your light flash or does it stay lit constantly?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
Your light should flash. A constant light generally means that your system is inop.
That may also mean that you need a new module.
found this @ circuit city what a great deal!! 200 installed!! http://www.circuitcity.com/ccd/bundl...20installation
Finally got it programmed......
Must have done the procedure 30 times over 10 days....but it finally came on and allowed me to program the remote. Got mine from keylessride.com for $45.00. Nice small thin remote. Recommend it.
Dave |
