need supplier for glass seal
Finally located a replacement upper passenger side fixed glass but now I need to locate a glass seal/weatherstripping for the piece of glass. I tried Subaruparts.com and some other online auto parts suppliers. No one carried the part. I know I did see the part on some site but can't recall where. Can anyone help?
Re: need supplier for glass seal
Which fixed glass are you referring to?
There are 2 seals (weatherstrip) for the fixed glass on the passenger door. For the rear fixed glass, the replacement part consists of the glass, bracket and weatherstrip all in one unit (but also available separately.) |
I need the seal/gasket for the rear upper fixed passenger glass. I was able to locate the glass section on ebay but it doesn't come with a new seal. I don't know about the bracket; thought I'd use the one I have once the shattered glass is removed. If not, I'll need to buy that as well.
Here is the part number that consists of the bracket part and weatherstrip:
90373PA001 - W/strip Ay Qtr Rh - $200.56 And here is the full assembly with the Glass (Bronze): 62203PA021 - Glass Qtr Upr Rh - $332.76 This is off of subaruparts.com. They should be able to order it for you and it may take several weeks to arrive. It shows as available, but not in stock, meaning it is at a Subaru central parts warehouse. Last edited by dbarnblatt; 07-31-2012 at 08:52 PM. |
Thanks. I had checked Subaruparts but couldn't find the parts. I really appreciate the help.
