Old 03-11-2004, 08:50 PM
Old Fogey
Scott, Glad you're happy with the Hellas! But a couple of things bother me. Why would you extend the OEM(18ga) wiring with 12ga? Kind of like adding a 1" pipe on a 1/4" feeder. Warm and fuzzy?
Just like my kids, asking for advice and ignoring it.
Enjoy!
Glenn
Old 03-11-2004, 10:07 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Because that's the wire i had laying around.
I can go back and re-do, but they're perfect as is. If anything DOES happen to go wrong, i'll re-do it with the relay.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 03-13-2004, 02:00 PM
assuming you were inspired by the Supertone-mania going on over at NASIOC, you should have read that the Hella's draw MUCH current, and the relays would be required to keep from toasting your wires. if you have to use them for an extended time (punishing some moron who cut you off), you could potentially cook your wiring.....
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 07-12-2006, 11:45 AM
I finally got around to installing the Hella Supertone horns in my SVX.
I mounted each horn separately on a 1/8" thick, aluminum "L" brackets, One horn is located where the stock horns used to be. The second horn is on the other side of the engine bay, in front of the ABS unit and angled to the right the A/C liquid tank. I grounded each horn separately to the frame to insure that if I develop a bad ground on one, the other horn will still work.
I added an additional 30A relay so that I would get maximum power to the horns. Since I have done the alternator wiring upgrade, the additional voltage should make a significant difference in the sound.
Both horns combined draw 144W, which translates into only about 10A. The horn and brake light circuit are fused at 20A. The additional relay is fused at only 20A. The power to actuate the relay comes from the stock horn leads.
Old 07-13-2006, 02:31 PM
Here is the diagram of the Hella relay installed in addition to the factory one.
Old 07-17-2006, 09:06 PM
Originally Posted by Bwana
How does the relay hook up? The instructions that came with them basically say: Plug in the positive, plug in the negative. That's all.
Do I take the power off the stock wires, and just extend the wires to reach the horns?
Disconnect the two power wires (18GA) from your original horns and tie both of them together and added to a piece of wire connecting to Pin 86 of the new relay
Connect a wire from the POS terminal of each horn and tie them together and connect them to pin 87 of the relay
Connect a wire from the NEG terminal of each horn to frame ground
Connect a wire directly from the POS terminal of the battery to pin 30, with a 15-20A fuse inbetween the connections.
Connect a wire from frame ground or the NEG terminal of the battery, to pin 87 of the relay
When you depress your horn button, 12V flows out of the original relay (used to sound the factory horns) and actuates the relay. This closes the switch between pins 30 and 87 of the relay, allowing full 12V current to the horn.
Use 14 gauge wire for all your connections. I used 12 gauge wire since I had a lot lying around. I soldered and shrink-wrapped all my connections to insure a good connection.
You will also find that the horn has a lot softer beep when arming and disarming the security system, as the require more current than the factory horns
Old 07-18-2006, 02:40 PM
The Hella horns work perfectly, and they are LOUD!!!
Much louder than by connecting them to the factory relay alone.
I took the horns apart and painted the bright red frames a deep charcoal gray metallic with clearcoat, so that they blend into the engine bay and have a more factory-like appearance.
When arming/disarming the security system, the beeps are subtle and barely discernable (which I like). But set the alarm off and watch out!!
I will post photos soon.
Old 07-18-2006, 09:40 PM
Another horn alternative is the Stebel Nautilus. These are compact electropneumatic horns designed for motorcycled, but have been used in cars as well. They are rated at 139db at 4 ft.
They are designed to me mounted with the "barrel" vertically. I think the sub compact would work the best as the opening of the horn faces the front of the car, not downward.
Here is the Stebel website: www.stebel.it
To hear a sound file of this horn, click on products, click on electropneumatics, then click on Nautilus.
You can buy them here: http://app.infopia.com/Shop/Control/...sid/0/rid/4056
Old 07-19-2006, 09:29 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
They look good, John. Cann't wait to hear them!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 07-25-2006, 01:38 PM
Here are some photos of the installation of the horns. The drivers side uses a bent aluminum bracket attached to the original factory bracket (with original horns removed)
The relay is attached to the fuse box bracket screw.
n
Old 07-25-2006, 04:52 PM
Speedklix's Avatar
Locker Link Solution
Well, the paint does hide em, but the red would have gone along with your batt.
Looks great though!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-25-2006, 10:13 PM
Bwana's Avatar
*Special* Member
I just brought my set back from my parents house in Texas. I'll have to install them again.
Maybe I'll try to find a way to make them show through the 97 grille.
