Old 05-08-2003, 09:14 AM
mbtoloczko's Avatar
sans SVX
removing dummy button...
I just bought a factory security system. I've read through a bunch of threads trying to figure out how to pop out the dummy button, but its still not clear to me. Can I just pry off the dummy button that sits in the location of security button, or do I need to pop out the entire button cluster to get the dummy button off? Thanks!
Mychailo
Visit my locker
Old 05-08-2003, 09:41 AM
You don't HAVE to remove the entire cluster to get that button off but I think you're going to be removing the cluster regardless.
Old 05-08-2003, 10:22 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
You'll need to pop out the entire cluster. Use a small flatbladed screwdriver on the outer edge (careful not to scratch the surround or dig into the switch) and pull with your index finger on the inner edge (closest the steering wheel). Should pop out easily. From there, you can figure how to replace the switch.
Randy Johnson
Mike Davis -- at Reading VI
Old 05-08-2003, 11:03 AM
mbtoloczko's Avatar
sans SVX
Cool. Thanks. I'm looking forward to the keyless entry!!!! :-))
Mychailo
Visit my locker
Old 05-08-2003, 12:38 PM
Aredubjay's Avatar
Enjoy it. I know I do. I only wish we had the Japanese "handle lift" keyless entry. The Japanese models were created so that, (as I understand it) depending on the number of times and frequency with which you lifted the door handle, it would unlock the doors. You could set your own pattern just like programming the remote.
Randy Johnson
Old 05-08-2003, 03:28 PM
montypython montypython is offline
Is it Summer yet?
Re: removing dummy button...
Just going from memory (dangerous at my age ) I think if you check Lwin's locker (Seraph) he has a detailed description, with pics on how to remove the buttons.
Colin
96 SVX LSi 85K (Sold)
04 Legacy Sedan 121K
06 Chevy Malibu 71K
13 Outback 0K
Old 05-08-2003, 03:37 PM
Is it Summer yet?
Re: Re: removing dummy button...
Just as I suspected - my memory HAS gone
It's not in Seraph's locker, but it's out there somewhere because I printed it off a while back (I think).
I'll need to check when I get home tonight.
Colin
06 Chevy Malibu 71K
13 Outback 0K
Old 05-08-2003, 04:02 PM
Aredubjay's Avatar
Since I don't have a dummy button, does that mean I can't drive my car?
Randy Johnson
Old 05-08-2003, 05:02 PM
I'd hate to see what Rob's dummy button does (will do) in his SVX!
Ramming spikes perhaps?
Old 05-08-2003, 05:37 PM
svxeno
For instructions on removing the bank o' buttons look for instructions on putting in those funky white gauges. It includes how to remove those.
Randy ii
Old 05-09-2003, 12:25 AM
Rnady II - your car is smoking!
