Old 04-24-2003, 02:17 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Fuel Pump Cutoff switch?
Where is the reset for the fuel pump cutoff switch? Brian is going to look at a 92 LS-Touring that has had the air bags deployed and it wont start. I figure that there is a cutoff switch that kills power to the fuel pump in an accident. is it built into the ECU? would resetting the ECU clear it?
Any ideas?
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 04-24-2003, 08:43 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
There is only a valve to keep it from spilling. There is no electrical shutoff that I can see looking at the FSM.
Can you hear the pump run briefly when you turn the ignition on? It should run for a couple seconds. Show him on yours before he goes to check it out.
Any CEL? Could be a cam angle sensor broken if the car has been hit in the front.
'20 Honda Ridgeline
http://www.x35design.com
Old 04-25-2003, 05:36 AM
mohrds's Avatar
Thanks for the info. Unfortunately the guy is looking to get about $4K for it and considering that it has qtr panel damage, busted windshield, deployed airbag, and front end damage, he decided to walk away from it.
Doug
1994 LSi (4/93)
2000 Ford Excursion
