Old 01-14-2006, 10:19 AM
NJSVX
Strut
I am looking to replace my struts and was wondering if there is any others that can be used besides the Koni?
Plus how often do they need to be changed out?
Thanks,
Adam
Old 01-14-2006, 10:40 AM
Earthworm's Avatar
Meow!
Well, aside from stock which are by far the easiest to change and the Konis that will take at least 4 hours to change some have experimented with Impreza fronts on the SVX rear.
Old 01-14-2006, 10:59 AM
If you change them, they probably will not have to be done again for 10 to 15 years. It would depend how many miles you put on the car.
Old 01-14-2006, 12:09 PM
NJSVX
Struts
Right now my 92 has 126K miles on her. They feel like they are slowly going. Any good sources for struts?
Cheers,
Adam
Old 01-14-2006, 12:42 PM
You can get stock ones from subaruparts.com.
Old 01-14-2006, 01:17 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Does Bilstein make struts for us? I know flatt-racing has a strut/spring set up for us but its like 3000$ I think.
dustin
-Dustin
Old 01-14-2006, 01:25 PM
Here you go ... some customized struts for the SVX:
Old 01-14-2006, 08:14 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Impreza struts will work just fine (fronts in the back). Just need to grind the hub down to size. Haven't experimented with the rears up front yet but they should work just the same from the looks of it again with the grinding of the hub and then you have the issues with the sway bar that really needs to go anyways I'm coming to realize.
Old 01-15-2006, 10:14 AM
mbtoloczko's Avatar
sans SVX
Cheers,
Adam
I recommend 1stsubaruparts.com. 866 528 5282. They have slightly better prices than subaruparts.com, and Jason in Parts is a great guy to deal with.
Mychailo
Visit my locker
Old 01-16-2006, 10:48 AM
NJSVX
thanks,
I'll give them a try.
Cheers,
Adam
