Old 07-28-2008, 09:52 PM
dromano's Avatar
dromano dromano is offline
Re: Front Wiper Control Unit
Originally Posted by TomsSVX View Post
Yea, don't disconnect the seat wiring until after all 5 bolts are out... Otherwise its a snap
I'm doing the front Oil seals/plugs, do I have to connect the battery to remove the drivers seat? 5 bolts are holding the seat in, yes?
Think I'll wait till I have the front of the engine buttoned up before I take the driver seat out, so much fun I could just s***.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 07-28-2008, 09:55 PM
TomsSVX TomsSVX is online now
lol, yea I would suggest tackling one thing at a time here
Old 07-28-2008, 10:10 PM
dromano's Avatar
Good advice and I'm taking it. I'm waiting for oil seals & an O ring to finish the front of the engine. The O ring is so flat, it has RTV on it, is that normal? The oil pump O ring is so flat on both sides, is it age or is this normal? The O ring is not an O, it looks like a round thing with 2 flat sides, is this normal after 17 years/117xxx miles?
Old 07-28-2008, 10:13 PM
yes... they are flat o-rings. The RTV is probably the "fluid packing" as Subaru refers to it, that seals the oil pump to the block. Make sure you follow the manuals instructions to installing it properly or risk having it leak
Old 07-28-2008, 10:23 PM
dromano's Avatar
Thanks Tom,
Will do, leaks? I don't want no f*ing leaks, I'll follow the advice of the gurus and
follow the manual instructions. I'll probably do more than the manual instructions
Old 07-29-2008, 07:54 AM
Thanks Tom,
Pick up some Perma-tex ultra-black and use it to form a thing bead around the mating surface of the oil pump. Make sure you make a bead around the o-ring but not enough to allow it to push into the 0-ring grove. Also, coat the threads on the three oil pump bolts on the right side (passenger side) of the engine. I will try and scan the page out of the manual for you when i get to the shop next.
Old 07-29-2008, 08:31 PM
dromano's Avatar
Tom, thank you, such good info. I have cleaned both flanges, waiting for O ring.
When I pulled the oil pump bolts each of them had gray RTV on the thread end, the bolt holes in the pump were surrounded with gray RTV. It looks like "clean both flange surfaces and apply the right amount of RTV". OK, don't over do it!
Old 07-29-2008, 10:23 PM
Just be sure to use a sealant that has good oil and heat resistance... Its a good idea to coat all of the bolt threads, but the book only requires those three
Old 07-30-2008, 07:41 PM
dromano's Avatar
Do you think Permatex Ultra Grey RTV will perform like Ultra Black? I have Ultra Grey due to Old Tom's advice. Used it on the water pump. I can't remember where it came from, but, I have a metal water pump gasket that I will use in combo with the fiber gasket and RTV.
Old 07-30-2008, 07:43 PM
huh?? I wouldn't use that many gaskets... there is no need to use any other besides the metal gasket itself... Never double stack
Old 07-31-2008, 08:33 PM
dromano's Avatar
If I use only the metal gasket, do I put RTV on both sides of It? I did both gaskets 7 years ago, no leaks, with blue RTV, inquiring minds want to know.
Old 08-01-2008, 06:54 AM
THere is no need for sealer unless there has been abnormal wear on the block or the pump that caused the face of either to become warped or marked, thus causing a leak... Otherwise, the metal gasket alone with no RTV should be all you need.
Old 08-01-2008, 12:06 PM
kwren's Avatar
kwren kwren is offline
use correct torque when tightening the bolts
Keith
Old 08-01-2008, 08:32 PM
Manarius's Avatar
Manarius Manarius is offline
Well, you thought wrong!! The front wipers have a "control unit", it is 2 3/4"X3 1/2". Now you know more than you knew before. Why bother posting if you have no clue?
In every other Subaru, the control unit is on the stalk itself.
-Jason
-Obi Wan Kenobi
Old 08-02-2008, 12:06 PM
dromano's Avatar
Here are a couple of pictures of the front wiper control unit it is a 17 pin module that is secretly hidden under the left side dash. Part #88571PA000.
The round thing to the left is a penny & the vise grip with the bent nail is my new oil seal puller Some day I will learn to use the digital camera
