Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 09-13-2006, 03:27 PM
Earthworm's Avatar
Meow!
Auto-X in the wet
Looks like it's going to rain all weekend here.
I've never run autocross in the rain before and would appreciate some tips with how I should set up my car.
Specifically I would like to know where I should be setting my tire pressures and Koni's.
For dry events I've been running the Koni's full stiff and tires 46F/42R although I probably should have had lower pressure in the back. Tires are Yoko AVS db S2's.
Thanks for any and all info.
Old 09-13-2006, 03:40 PM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Keep the Koni's as stiff as they'll go... I'd run alittle less pressure though... Maybe more like 42F/40R... I tend to not change he car much depending on conditions... I just drive it, and Drive the piss outta it at an Autocross in the rain!!!
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 09-13-2006, 07:40 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
David,
When autoXing in the wet, you need to be as smooth as possible. Every input you make - braking, acceleration, turning the steering wheel - has to be done in a very gradual, non-abrupt manner. The limit of adhesion will come much sooner, so always be mindful of this.
Look ahead...as far down the course as possible as you can't let a tight corner sneak up on you. In the dry you can sometimes get away with not running the optimum line, but in the wet it's paramount that you stay on it - always try to make turns as wide as possible and late apex to make the straights as long as possible (by the time you pass the apex cone more than 50% of your turning should be completed).
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-14-2006, 10:28 AM
Earthworm's Avatar
Meow!
I'll let the driving take care of itself
I'm mainly curious if the Koni's should really stay full stiff and what a good tire pressure to run would be.
Old 09-14-2006, 11:53 AM
Chiketkd's Avatar
Well good luck to you Sir! Definitely keep your suspension settings the same.
Old 09-14-2006, 12:27 PM
Mr. Pockets's Avatar
Moderator
I'd really like to do more events in the wet. We don't have many here - rain usually means thunder and lightning, and at that point we run for cover.
The MR2 is a lot of fun when it gets slippery. It's a challenge, but a lot of fun.
Chike's right, you're going to need to be extra smooth. I've never autocrossed my SVX, but I can imagine it plowing ferociously if you push it. As for setup, I haven't the faintest. On my MR2, I'd be inclined to soften the struts slightly, but not by much. I have my preferences depending on the surface we're using, so obviously I'd start from there. If the surface is extra-smooth, you can get away with a lot.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
