Dropping resistor repair
My dropping resistor blew so I looked up my resistor options on my favorite electronics websites, Digikey and Mouser. I couldn't find a ceramic resistor option I liked so I bought a thick film resistor that could be heat-sunk. It can operate at up to 100W if properly heat-sunk at room temperature. I probably didn't need to but I added a TO220 heat sink to the stock housing. I used thermally conductive RTV between the resistor and original housing, as well as around the solder joints. I used Arctic Silver between the heat sink and housing. They are all held together tightly with a 6-32 screw. .
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by svxcess; 12-02-2018 at 12:33 AM. |
Re: Dropping resistor repair
How is this holding up? I am very interested in doing this myself.
Thanks!
