Old 09-05-2014, 06:17 PM
michael's Avatar
michael michael is offline
What Potholes ???
ABS coming on for no reason
Sometimes when I come to a slow stop by ABS will activate when there is no loss of traction. I also hear a cartoon like spring sound when it comes on, like a "doing" sound. Anyone have any ideas?
Wanted: Steering Wheel
Old 09-05-2014, 08:10 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: ABS coming on for no reason
Check your tone wheel. There may be a break or a crack.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 10-12-2014, 11:41 AM
michael's Avatar
What Potholes ???
I will check for that. I read somewhere online that low brake pads can cause this. Is this true? I just changed these today.
Old 10-13-2014, 01:57 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
WOW!!!
that is super scarey to think you have that much stopping power !!!
Old 10-13-2014, 05:52 AM
michael's Avatar
What Potholes ???
The wear indicators didn't even make a peep. Another week and I would have had a new wear indicator.
Old 10-14-2014, 05:41 AM
Blacky Blacky is online now
Do you have any binding in the rear? When my transfer solenoid was dying and dead, the ABS would engage all the time because of the back wheels dragging. After I replaced it the ABS issue was gone also.
P.S. I just replaced the rear pads on the '97 and they looked just about like yours. They too never made a sound of warning.
Old 10-15-2014, 03:19 PM
Low pads won't cause the abs to kick in. I'll bet it's a cracked/damaged tone wheel.
Old 10-15-2014, 05:27 PM
michael's Avatar
What Potholes ???
I think you're right. It's still doing it
Old 10-16-2014, 06:57 AM
The worst part is if that's the case, the bearing/hub has to be separated to replace one.
Old 10-16-2014, 05:44 PM
Tireiron Tireiron is offline
Just take out the ABS fuse from under the dash and enjoy the way a car is supposed brake. Subaru ABS is horrible anyway.
Old 10-16-2014, 07:03 PM
michael's Avatar
What Potholes ???
It would be easier to replace the whole works, no?
I would, but I have issues with hiding problems
Old 10-17-2014, 05:51 AM
dannmarr's Avatar
I work for my SVX
The hub assembly needs to be removed to access the tone wheel for replacement.
Subaru SVX for fun
Old 10-17-2014, 01:35 PM
wdb wdb is offline
dances with roads
I had this happen to me too.
Are you getting a code? Could be ABS sensor if you are.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 10-23-2014, 04:59 PM
michael's Avatar
What Potholes ???
My LED is flashing 5x, could this just be the sensor? If its the tone ring, I'm just going to grab a whole hub at the junkyard. Seems like an easier DIY. btw it read front Left - Driver side I presume?
Old 10-25-2014, 03:29 PM
michael's Avatar
What Potholes ???
Any idea? Ring or Sensor, Driver or Passenger side? I glanced at the ring today and didn't notice any cracks.
