going to need some parts fabricated
I'll be needing the following parts for a custom SVX build i'll be doing soon. If anyone can make these parts, post here or PM me. 'm looking for good
workmanship at a resonable price. I can supply most of the parts, just need them fabricated. 1. 6 speed tranny cradle/mount 2. turbo engine crossmember cut for a up-pipe 3. rear crossmember for a R180 (STi rear) 4. 6 speed shifter that fits the SVX 5. hydro operated clutch set up with a DBW gas pedal 6. hood with a scoop? thanks |
-Bill
2. turbo engine crossmember cut for a up-pipe- I have a full subframe... Just need to know where you need it cut and welded 3. rear crossmember for a R180 (STi rear)- You can notch the underbelly strap for the rear or leave it out like I did 4. 6 speed shifter that fits the SVX- I can make one in the next couple days 5. hydro operated clutch set up with a DBW gas pedal- I think I have a DBW gas pedal actually but not sure if it has the pedal cover. I can also make you a set of hydro pedals that fit the SVX to a T using the SVX frame and WRX guts... You even get to keep the SVX brake booster... Let me know if you want me to get to work. It's $800 for the 6mt conversion kit... which is what you need Tom 6. hood with a scoop? |
1. 6 speed tranny cradle/mount- got one sitting in the garage as we speak
i'll let you know when i need it. 2. turbo engine crossmember cut for a up-pipe- I have a full subframe... Just need to know where you need it cut and welded i'll have to get some measurements for you. i'll have one for you for a core. 3. rear crossmember for a R180 (STi rear)- You can notch the underbelly strap for the rear or leave it out like I did ok, i guess i can do that 4. 6 speed shifter that fits the SVX- I can make one in the next couple days i have a new one you can use to make one. 5. hydro operated clutch set up with a DBW gas pedal- I think I have a DBW gas pedal actually but not sure if it has the pedal cover. I can also make you a set of hydro pedals that fit the SVX to a T using the SVX frame and WRX guts... You even get to keep the SVX brake booster i have a new DBW pedal and a set of WRX pedals along with the hydo slave cylider. when i get the stock SVX pedals i can give them to you for a core. sounds good. pm me a price for everything as i will supply parts and give you cores. thanks |
cores are good for $100 off. Depending on how much time I log on the Subramfe will determine how much it will cost.... I gotta see if we can put the DBW ass. on the SVX pedal... will let u know
Tom |
<<I believe Dayle carries #6>>
i looked on his site and they only have the scoops that you bolt on. does anyone make a one piece hood with the scoope built in? thanks |
ummm... on Dayle's website they have a fiberglass hood with a All-Trac/Impreza style functional scoop. The hood probably weighs a good deal less. Look a little harder in the 'Exterior' section
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
