Sunroof Problems
Im having a problem with my sunroof, it will open all the way just fine, however when closing it will only get to the point where it stops prior to closing all the way, and then will not drop down when you push the button.
Anyone have any idea other then cleaning the tracks?
1992 Liquid Silver LS-L (Sold-5/16/13) 1997 Spruce Pearl Outback (Sold) 2006 B9 Tribeca |
Mine does the same thing... once it gets to the point where it stops, back it up again and then make it go forward. It works on mine. Hope it helps.
Nick,
Apparently that used to work, Then I bought the car! Michael, I saw that thread when I did my search (Im only a semi-n0ob) and Im going to give it a shot, but really don't see how it will help, as at some point the slack should be taken up anyway (meaning it may be slow to close, but should still close eventualy) Thanks to both of you Any other suggestions out there??
