Dr. SUS in the house!!!
finally got to drive it today MAN this thing is FAST!!!! There still is some loose ends that need to be figured out with some of the wiring but it runs and drives!!!! I need to wire in the proform push fans I have here for it and I need to get the dash working... I am loading videos on Youtube as I type this... Just firing it around our gravel lot at the shop, it needs some plates and insurance before it hits the streets... and then the trails!!!
Tom |
That thing looks awesome. Seen in person and i can't believe how they managed to cram that engine in there. Great job guys!
Looks cool, have fun with it.
I guess it will be at Reading?? Quote:
Tom:
Post some pics with the hood open so everyone can see exactly what you've done Dan
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Was that 3rd video ended right before you slammed into the garage door? That's where it looked like you were headed...
PICTARS
tOM |
Hey:
I recognize that snorkus. Either I wrapped the insulation around it myself, or the sincerest form of flattery has been offered in this intake tube. Either way, glad to have been able to make even a minimal contribution to this fine effort. This is a picture of it in its first incarnation, replaced by the fine Tomyx custom intake snorkus.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 03-18-2008 at 06:13 AM. |
Yea Dan, due to the legacy airbox being located just slightly off of where the Stock SVX airbox is, it made a poor fit for the stock snorkus... So we hhad to use yours make it somewhat "adjustable"
TOm |
That's awesome! If nothing more than to see yet another crazy plan come to fruition.
So all this talk about it being fast... are you saying it's faster than the supercharged SVXes, 4.44's, and all the other goodies you got going on? What makes this thing so fast? Is something done to the engine? It's N/A right? It seems like every time the EG33 is dropped into another vehicle it is faster than the SVX, even back to the days of Smallcar installing them in Vanagons. Why? Looking at the parking lot shots with the cars side by side, it's a crime if the SUS is faster than any of those SVXes. I know sleeper cars are cool, but it's still a crime. BTW, is this going to remain in full SUS trim and be utilized offroad?
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Tom:
Like I said, it is a privilege to make a contribution, however small, to this worthy endeavor. Dan
Yes I do plan on keeping in SUS trim and take it to the trails to do some rally driving My wagon has been subject to some offroading but the SUS seems so much more capable I cannot wait to get the reg. on it this weekend and take it to the streets I will take it on the trails this weekend during out meet, hopefully we can take a break from the shop and all head to the trails for some good fun Tom |
Yay tires are here... now to go mount and balance them when I run my errands
Tom |
Loading pics of the front end rebuild and the tires before/after
Tom |
Tom |
