Starter interrupt relay? please help
Does anyone know what and where this is located on the SVX? It looks like it is a part of the Security System bot if so, where is the security module located on the car. If not, where is the security module located on the car anyway? Doesn't show up on subaruparts.com and the Subaru dealers have no clue if there is a starter interrupt relay.
KWren |
I'm not really sure where the starter interrupter relay is, but I believe the security system module is behind the glovebox.
Thanks a bunch!
The security module is behind the glovebox on '92s, but at some point was moved to inside the trunk, beneath the package shelf; I guess whenever they went to a passenger-side airbag. Do a search for more info.
dcb |
Thanks for the information!
KWren |
The "starter interrupt relay" gets a signal from pin 13 on the security system computer.
The interrupt relay is connected to a square, white, 4 conductor plug. According to the FSM it appears to be located under the drivers side of the dash, it appears to be the connector closest to where the wiring harness goes through the firewall. It has 4 wires going to the relay; Pin 1 - Blue/Red - 12v+ from fuse 23 (inside fuse panel) Pin 2 - Black/White - Ignition Switch Pin 3 - Blue/White - pin 13 on Security Module (above glovebox, or under rear deck if car has PS airbag) Pin 4 - Blue/White - Inhibitor Switch (Switch is along drivers side of transmission, Connector is one of the large connectors that goes to the transmission under the hood, this one has 12 wires) I'm guessing wire 2 and 4 are going to be thicker than 1 and 3???
Re: Starter interrupt relay? please help
Edit: Quoted the wrong person.
