Noise in rear
Not sure what this could be, but curious if my AWD clutches are binding:
At very slow speeds....particularly in parking lots while coming to a stop and turning or starting to accelerate when turning, I hear this low bass noise from the rear....small vibration with it. Can anyone tell me what they think is going on?.....I'm not sure what a failing bearing sounds like in this car, my tires are all the same size and tread is worn evenly on all.....so what's left? something with the differential, etc? What is a typical cost to fix the AWD clutches if they are worn? Thanks, |
Have you rulled out the wheel bearings? The next thing you can do is go to a parking lot with lots of room. Do some figure eights (slow speed - not donuts) which would be hard over to hard over in the other direction. Check to see if you have binding or clunking sounds. Good luck.
I would put in the fuse (10 amp under the hood in front of overflow bottle) to make it temp FWD and try to see if the sound persists.
It happens when you accelerate AND when you Brake while turning?
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue |
Figure 8's sound fun......should I use the fuse when I do the 8's or do them before I check the system with the fuse
Also when I put in the fuse, what will I notice....anything on startup? any blinking lights on dash?.....And when I take it out, should everything be the same way it was before it was put in? |
I think it only happens when I press the pedal and turn slow.......I ruled out wheel bearings just because I have been driving through the city and highway and didn't notice any noise or feel any vibrations.....
If it happens on acceleration only, my guess is you have a U-joint going out on the prop-shaft.
Do you get any of the symptoms if you just floor it in a straight line? By putting in the fuse you disengage the power to that half of the car. If you still get the noise/symptoms with it in, that pretty much rules out the prop-shaft. Go thorugh a specific series of moves with the fuse out(normal), then duplicate that with it in.
Lay off the beans!!
Seriously though, at what speeds do you hear this noise?
