Wiring Harness
I recently bought a used harness from one of the guys on here, and was wondering if anyone had a list of what the colors are supposed to corrospond with.
I have white, gree, purple, grey, orange all as a pair (one wihout and one with a stripe) then i have a black, red, and blue.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit. Next changes ... PAINT, fix engine problems, 4.44. (GONE) '97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE) Last edited by etz bseder; 12-04-2006 at 08:48 PM. |
just match up the colors with the stereo, but in general:
black is ground blue is antenna/amp orange is illumination red is ACC yellow is battery white,gray,greens, and purples are for speakers, make sure you have the polarity right though. Last edited by nysvx10; 12-05-2006 at 04:30 PM. |
Alright, and if I have a sub, does that have to be turned on only when the auto-antenna is powered on?
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit. Next changes ... PAINT, fix engine problems, 4.44. (GONE) '97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE) |
Are you going to be powering the sub by a amp?
There's a wire color / pinout table here: SVX Audio Installation Guide
If your HU has an amplifier remote control wire then use that. If not, you'll have to control your sub from the +12V accessory line (so it will be "on" whenever the ignition key is on, regardless of whether your radio is on). If you think you'll drive around a lot with the radio off, you can add a switch to this wire to disable the sub.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
