Old 01-15-2017, 02:39 PM
epesposito epesposito is offline
SVX Key Fobs
6 SVX Key Fobs - may work, may not - make offer
Old 01-16-2017, 03:51 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: SVX Key Fobs
Are these the ones on eBay ? If not, more details maybe..clickers work, internals corroded from old battery..? Pix would be great. I am interested, not just wasting time.
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod.
Old 01-16-2017, 05:02 AM
theflystyle's Avatar
Re: SVX Key Fobs
Ive asked for internal pictures of the ones on eBay and the seller never complied. Hopefully these turn out decent.
1994 SVX LSi
2008 Legacy 3.0R
Old 01-16-2017, 05:10 AM
fasteract7's Avatar
Re: SVX Key Fobs
Some of the common problems with the used ones are....plastic flap with orange dot hinges are broken, metal spring wire on neg. battery side soldered joint broken, internal button for pressed flap doesn't "click", plus the electronics are bad just cuz or from battery corrosion seepage.
Old 01-16-2017, 02:15 PM
Re: SVX Key Fobs
These are not on ebay. Will provide more info as I examine them more thoroughly and will see about sending pix.
Old 01-16-2017, 02:17 PM
fasteract7's Avatar
Re: SVX Key Fobs
Great, much appreciated...
Craig
Old 01-17-2017, 09:16 AM
Re: SVX Key Fobs
Craig,
These 6 key fobs have not been posted on ebay or any other site. While cleaning out files, came across these in a plastic bag. They are what is left over from the 5 SVX's owned and no idea if they work or not. The red buttons click on at least 3 of them.
