Rear deck de-ioniser with fan
Super rare in the USA...
https://www.jauce.com/auction/c572707772 https://www.jauce.com/auction/q131196950 Sad but what is currently missing is the timiing module that is located in the rear side window area on the LHS, plus the wiring loom from under dash area to the rear. Here is what I suspect to be the part (from same seller) but no photo of rears ... https://www.jauce.com/auction/b229360638 Dont forget that you will also need the mating connector for the switch.
Re: Rear deck de-ioniser with fan
update - have found the control unit for the item, it is in the rear of one of the panels on the following site - the metal bracket section
http://www.jauce.com/auction/b230749153
