AWD Inoperable - Speed Sensor 2?
I rarely post technical questions, as normally I only drive my svx about 1000 miles a year and typically don't run into issues.
New high mileage svx = new problems to play with! My SVX's rear wheels don't appear to be getting any power. The only code I'm getting is for speed sensor 2. Could this cause the issue? Where is speed sensor 2 located? Mike
Re: AWD Inoperable - Speed Sensor 2?
If I am not mistaken, it is the one in the front diff.
Isn't the one in the front diff the one that drives the speedometer?
I thought thats Speed sensor No.1
Could well be. In my Euro book the front one is speed sensor 2. No.1 is at the rear of the box.
The US one may be different. Harvey.
You probably already know this but have you checked whether the 10A fuse is inserted in the fuse box under the hood? Because if it is, this deactivates the rear clutch and the car becomes 100% FWD. That's Front WD, not Four WD, OK? People sometimes do this if the car is binding from solenoid C problems like Bill mentioned. If that fuse is in place, which it would normally be only for maintenance or dyno testing, you should have a FWD light on the left of the dash. Joe
I will likely replace the solenoid and see if that has any effect. Can I use the solenoid C out of any Subaru 4EAT, or does it have to be from an SVX? I have several parts transmissions at work and this is just for my "beater" svx. Mike
One word of caution! Use a C solenoid from a 92-94 car. We have determined that the later solenoids work in reverse to the early ones, so you need the type that works with the instructions from your TCU. Joe
OK. I did some diagnosis today. The Speed Sensor 2 code was based on what the previous owner had told me. I didn't pull the codes until now. I pulled the codes initially from the transmission and got fault codes for both speed sensors and duty solenoid A. I cleared the codes and went for a drive.
First, I observed the output from both speed sensors. They were correct and matching throughout all speeds up to 60mph. The transmission shifts perfectly, but the awd doesn't work. Upon returning, I checked the codes again. The only one that reappeared was duty solenoid A. Any thoughts?
Mike
I really don't know. Hopefully either of the Toms might chime in. Duty Solenoid A is the line pressure control solenoid. By itself this solenoid would not cause you not to have rear wheel drive. At least I think not. There must be something else amiss. Joe
