Old 06-08-2007, 05:11 AM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
manual gearbox owner question
i was wondering what everyone or anyone is using to reduce noise where the shift stick is? sometimes the noise isn't that bad and sometimes it really rattles.
thanks
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 06-08-2007, 08:14 AM
thanks
If it really "Rattles" then you probably need new shifter bushings, or the little spring on the shifter to hold it off to one side.
If everything is as it should be, the shifter should not rattle at all.
Old 06-08-2007, 08:45 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Also it will rattle if the bushings are overtighened in there as well. Some slop is good, no slop or too much slop means rattling! I'd go with Hucks diagnosis unless the bushings were replaced on the swap or were retightned when shortening or lenthening the shifter rod.
