Old 10-27-2006, 11:37 AM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
Engine dies while driving
Haven't been to the forums in a long time. Good to see that it's still going strong.
I am having an issue of of the engine dying while driving.
Is there anything easy I can check on this?
Sometime all the warning lights go up before the engine dies. If the fix is too costly I am probably going to have to trade it in.
Anything obvious I should check before taking it into the shop? The fluids all look normal.
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 10-27-2006, 12:23 PM
SVXtacy SVXtacy is offline
Alternator.
Old 10-27-2006, 01:15 PM
Does it start right back up?
Does it have to be jump started?
Old 10-27-2006, 02:29 PM
htyei's Avatar
It starts right back up. When it happens, I turn on my hazard lights, put it into park and restart it with no problems. The negative battery terminal seemed loose a few days ago, so I made sure they were tight and non-corroded.
Henry Yei
htyei@svxwrx.com
Old 10-27-2006, 02:54 PM
Earthworm's Avatar
Meow!
Any stored ECU codes? Possibly a cam/crank sensor or even the MAF sensor.
Old 10-27-2006, 02:58 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Alternator, battery or wires in between.
Old 10-27-2006, 03:16 PM
Manarius's Avatar
Manarius Manarius is offline
I smell the blood of a dead/dying MAF. The fact that it starts right back up screams MAF to me.
-Jason
-Obi Wan Kenobi
Old 10-27-2006, 03:47 PM
Mr.Pwrlite's Avatar
Mr.Pwrlite Mr.Pwrlite is offline
I'd say MAF too, but check the codes and see if anything else come up
"If it works, tear it apart and find out why!...... "
94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ...
Old 10-28-2006, 03:38 PM
Shadow_Myst Shadow_Myst is offline
Plugs and Wires?
Have you changed your plugs/wires and cap and roter any time recently? Are there any other symtoms?
-=SM
Old 10-28-2006, 03:45 PM
-=SM
there are no plug wires, nor Roter button, nor distributer cap on a EG33....
Old 10-28-2006, 11:12 PM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
one of three things, mine is all three... MAF is going or gone, Throttle bodies need to be cleaned, or the alternator is beginning to go. mine was all 3, ugh
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 10-29-2006, 02:29 PM
htyei's Avatar
Yikes, these are the codes I get (and cross indexed with their meanings from svx-iw.
Should I clear out the codes and see if any or all come back?
I haven't cleared out the codes in years.
ECU error codes:
24 By-pass air control solenoid valve By-pass air control solenoid valve inoperative.
(Abnormal signal in monitor circuit.)
32 O2 sensor 1 (RH) O2 sensor 1 inoperative.
34 EGR solenoid valve EGR solenoid valve inoperative.
37 O2 sensor 2 (LH) O2 sensor 2 inoperative.
56 EGR system (CAL.) EGR calve open/close stick, EGR hose disconnect or exhaust pressure valve damaged.
Henry Yei
htyei@svxwrx.com
Old 10-29-2006, 07:50 PM
That's a lot of codes...check you grounds on the motor.....and the main engine connections...
Old 10-30-2006, 02:22 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I had similar symptoms due to a tank of bad fuel. No ECU codes stored though. Did the problem start just after the last time you filled up?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 10-30-2006, 09:40 AM
htyei's Avatar
While my check engine light had been on and off for a very long time. All the actuall perceivable problem did seem to start with my last gas fillup. However it is still happening after I filled it up again (albeit form the same gas station)
Henry Yei
htyei@svxwrx.com
