OEM adjustable headlight diagram required
Hi folks,
just received from UK a set of glass headlights with adjustable switch (0-3 positions). Since I cannot locate OEM mating connectors, I require a wiring diagram so that I can use my own mating connectors. Please note that this is not available in the USA manuals (unless I have not got all the addendums for 92-97). Can you PM me a copy of wiring diagram - thanks, or point to a link?. thanks
