Old 09-01-2009, 06:23 AM
SVX_MY_BABY's Avatar
Re: So I was driving back to campus last night....
Originally Posted by AltaSVX View Post
thanks for all your responses, the belts are good and tight so I guess its probably the alt then...and if it is that easy to switch out then maybe I can cobble together enough tools to do it. Does the alternator usually affect any other electrics when it goes? Anyone know off hand exactly what you need to take the guard off, loosen the belt and take it out? I am not the most knowledgeable when it comes to mechanics but I do want to learn and the alternator is pretty really accessable. Thanks again.
Very good document on this in the "How To" section above.
Also do a search on alternator or steering Belt tension. It will pop up a few detailed threads with photos.
Old 09-01-2009, 07:46 PM
AltaSVX AltaSVX is offline
Again thanks for all your replies. I'm 99% sure its the alt....not running, the multimeter read 12.1 V, running 11.7 and with everything on, a little below that and the car died when I disconnected the battery. The sound in question seems to be coming from the alt as well. I'll get a chance to pull it out this weekend but again all your responses have been a huge help, and I'll let you know how it turned out.
1994 Subaru SVX LSi Pearlie 123,000 Km
Old 09-20-2009, 10:10 PM
I know its been a bit but I thought I would give an update. Finally got around to pulling out the alt and picking up a replacement. Got her installed and voila, all the dash lights are off, took her for a test drive and so far so good. Total cost ~$100 including a mickey mouse metric socket set. Thanks to everybody who posted and the beers on me if any of you guys come up to Canada.
Old 09-20-2009, 11:08 PM
The update and resolution helps others who are searching and have the same problem
Glad everything is worked out at not too high a price
Old 09-21-2009, 12:21 AM
kwren's Avatar
kwren kwren is offline
The voltage you are reading is probably only battery voltage...
Keith
