Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #121
Old 09-18-2006, 10:10 PM
longassname's Avatar
Just some dude.
I think you mean IAC valve (idle air control valve) which I doubt is broken. This is just a guess but I am guessing tom bypassed the cold air bypass valve and put your little ballcock device in the middle of a hose going from the outlet on the snorkus and the inlet on the throttle body. It sounds like you just made that a straight hose going from the snorkus to the throttle body. That will give you way too much air at idle. The hose from the snorkus should go to the cold air bypass valve and then a hose from the cold air bypass valve should go to the throttle body. The cold air bypass valve is underneath the manifold on the driver's side.
Originally Posted by gest24
Just got back from cruising around SD. The new version is nice. Snappy and quick. The dyno shop I usually go to was closed so I'll have to try another day to get dyno time and see how the new plots look.
My only issue was with the isis valve. I removed the bypass that Tom and I put on and replaced it with a straight piece of hose. But then the car was idling at 3K. Is my isis valve messed up from the bypass or do I need a check valve in the hose?
Old 09-18-2006, 10:32 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Gotcha, makes sense... I didn't pay attention when we took the hoses off. But other than that, the new software is awesome!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 09-24-2006, 01:39 PM
Just some dude.
Have you fixed your hoses yet?
Old 09-24-2006, 01:44 PM
gest24's Avatar
#1 6MT In Cali
I've been super busy with work and getting my old tranny packed up and ready to ship. I plan on putting her up on a stand this week to check some things underneith and I'll fix the hoses then.
Does anyone happen to have a picture of the Cold Start valve?
Other than that I love the new chip! My fiance even noticed a difference in the car, lol.
RIP
84 VW Scirocco
02 WRX
Old 09-24-2006, 04:03 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
*snip*
and you needed a chip for this to happen?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-24-2006, 04:19 PM
gest24's Avatar
#1 6MT In Cali
-Bill
lol, It was just surprising she felt a differnece between 2v5 and 2v6.
RIP
84 VW Scirocco
02 WRX
Old 09-24-2006, 05:27 PM
SVXRide's Avatar
-Bill
Old 10-03-2006, 07:33 PM
Just some dude.
Any more feedback? I'd like to hear impressions from everyone running 2v6?
Old 10-04-2006, 08:45 AM
SVXRide's Avatar
Michael,
I'll have to install one first
-Bill (still finishing up dyno R&D report...)
Old 10-04-2006, 09:02 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
I'm looking forward to that post!
Chike
2006 Steel Gray WRX TR (sold)
Old 10-05-2006, 01:40 PM
gest24's Avatar
#1 6MT In Cali
Mike,
I'll be autoXing with the 2v6 software this weekend. Going to be a different course than last time but I'll def. be able to notice any difference. I'll post up some results after Saturday.
So far I really like how the chips work. You can fell a ton of tourque even in 6th up hill.
RIP
84 VW Scirocco
02 WRX
Old 10-05-2006, 02:27 PM
dcarrb dcarrb is offline
Just passing through, and I've not waded through half this thread, but to revisit the E85 issue, I think it's noteworthy that Subaru specifies up to 10% ethanol is cool. If anybody cares what the manufacturer thinks, there you go. (Pardon me if this has been mentioned.)
dcb
Old 10-05-2006, 03:26 PM
ethanol better be good because I run 10% all the time with the fuel in Jersey. Sometimes it can be up to 15% but mostly 10
Old 10-07-2006, 12:21 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
This looks good. I spoke with the head of the chem. department who instructs my environmental chem. class at su, he has some concerns about the possible wear on the fuel system, but we didnt have time to go into details.
Old 10-07-2006, 09:12 PM
Thats why I sent several parts to PhastSVX to be tested in a corrosive batch of E-85. Fuel pump, fuel rail, o-rings, etc.... with a dash of water mixed in, we will see what our fuel systems will do with E-85
