Crank grinding limits
Does anyone know what the limit is to grind the crank pins on our cranks before they are past the point of no return. I have a crank that all the rod pins are in the 2.0465-2.0455 range except the first which is 2.028 at its lowest. Is this crank able to be salvaged?
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
Re: Crank grinding limits
Well you can get good bearings as big as 0.075" undersize.
King Engine Bearings SI series rod bearings: CR4125SI075 Assuming your crank isn't bent it isn't anywhere near needing to go to a bearing that big. Why do you think your crank needs to be ground to begin with? |
