Oxygen sensors, so many to choose from.
My 92 ebony popped an O2 sensor code yesterday. The check engine light was only on for a few minutes but I decided to have it scanned anyway.
I've seen prices ranging from $118.ea from subaru parts.com, to $80-ish ea from auto zone for bosch or denso exact-fit. Is one better than the other? Thanks.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU. 77' IHC Scout SSII |
Re: Oxygen sensors, so many to choose from.
You can source an OEM NTK replacement from places like Rock Auto. The part # is NTK 24614. They should be around $37.79.
'92 SVX LS Pearl White - 6mt |
I agree with the NGK/NTK sensors.
The most reliable, and the cheapest, O2 sensors I have found. Had them in since February 2010 and still perfect. Amazon.com has them for $41.11 http://www.amazon.com/NGK-24614-Iden...ords=ntk+24614 NTK is the world's leading manufacturer of OEM oxygen sensors and supplies more vehicle manufacturers with oxygen sensors than any other company. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-01-2012 at 12:40 PM. |
I third this suggestion. I tried the Bosch with mixed results. My next sensor will be NTK.
Just make sure the O2 sensor has the plug on the end for easy replacement. Some cheaper versions don't have it and you will need to splice it.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
The NTK sensor I listed does.
The 02sensor may not even be bad...
Keith |
