Getting Ready for Summit Point
Will be at Summit Point this coming weekend (August 25-26) for two track days with NASA Middle Atlantic. We'll be running on the main course. Got my New Bridgestone RE01-R's (245/40-17) mounted and on the car. Just bled the brakes. Thern the rain started to fall before I could get a picture of the tires. But I'm ready to roll. Anyone want to drop by Summit Point, would love to see any fellow SVXers.
A question about heat cycling the tires. These aren't really R compounds. They have a wear rating of 140 as opposed to 80 for typical R's. Does anyone think I really need to go to the hassle of running them up to temperature and then taking them off the car for 24 hours? Anyway, maybe none of this is applicable to these tires? Any thoughts?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
No you should be fine with heating them up and letting the 'em on the car. Just move it every few hours while sitting for that resting time.
Wish I could make it down. If it was 2 weekends later I'd be riding right past ya and would have to stop. That reminds me I need to see if Harry is running an autox in Winchester the weekend of the 6th. |
Sorry I did not make it to Summit this weekend. I hope all went well. The tires really look good. I'm sure they performed well.
Ben, I do plan to be at autocross with the Mercedes Club in Winchester - but the date is Sep 9, not Sep 6. I am about 98% recovered from my surgery now, but I'll probably be sore as hell on Monday following the autocross. Are you able to come down? You know, of course, we are now running at the Millbrook High School parking lot. This is just EAST of Winchester on Route 7. Hope to see you there...... Harry
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
