94' SVX - Does not start - Code 11?
Hey,
First of all, I'd like to thank the administrators, moderators and all members of this site for keeping an encyclopedia on SVXs going. I have to say that the info on this site has helped me a lot over the years. THANK YOU! But, this problem is a doozy. It's a red 1994 SVX LSi that's been converted to 5spd from a 06' impreza donor; that's pretty it in terms of mods, rest is standard but it is for sure my most fun and reliable vehicle for the last 4 years. This spring, when i took it out of storage to get it prepped for summer, i noticed it took a while longer to start (I didn't think too much of it). I did however run it for about 2 months but the problem gradually got worse. To the point that sometimes i would have to use the slope of my driveway to bump start it. Finally I took some time to look up the codes and i got 11, 31 and 33 (this last one is because i never hooked up the speed sensor after the swap). So due to the no start up issue, i started with code 11, crank angle sensor 1. After removing sensor #1 (sensor at 10 o'clock), i checked its resistance readings and they were good. Even checked for AC voltage when moving a magnet in front of it and it would show change in reading. I then removed sensor #2(vertical one) and got no readings in either test, which was weird since the code was for sensor #1. I decided to order a replacement sensor (no OE available anymore, so went with a 03' impreza one) and then replaced it. Tried to start it, but no luck. Swapped the 2 sensors, still no luck, and now i'm stuck! Has any of you come across this kind of issue? Are my wirings correct? I feel like i'm missing something here (probably something stupid). I'd really appreciate any help. Also, is it an issue starting the engine without the alternator (just getting a bit lazy with having to remove it every time) Note: the connector housing was removed to ensure i was connected the ground wire to the left pin of the sensors. |
Re: 94' SVX - Does not start - Code 11?
I had this same issue last fall. I ending up putting in 2 new sensors and it started right away.
Every time I have removed one of these sensors which has been on an engine for many years, it has ended up damaged from the removal. Once I sold one I removed from my running parts car, shipped it to a member of this forum and he returned it saying it did not work. I removed and installed them a zillion times and each time I connected the alternator. Don't take a chance out of laziness.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 07-15-2019 at 03:33 AM. |
Thanks for the reply, yes replacing both sensors does make sense. So, I did order another replacement, will give it a try this weekend so fingers crossed "X"
And yes, will take the non-lazy and right route of installing the alternator |
Ok, got an update with some good news and bad news. I received a second crank angle sensor from 03 Impreza (Standard Motor Product PC159). Installed it with no luck at first, but once i figured which pin of the sensor was the ground and signal wire I FINALLY GOT IT TO START! Best start in a few months, once warmed up idled around 750 RPM like it should (used to idle at 1000 RPM but i thought that was something to do with the 5Spd swap). The only CEL that came up was the vehicle speed sensor which i knew about.
However, got the bad news when I went to rev it and it would misfire real bad above 1500 RPM and wouldn't go past it. https://youtu.be/Wo9tmD8nuF0 So between the 3 good sensors I have (OE #1 and 2 PC159 sensors, OE#2 read no resistance) I tried a few combinations but the results got worse or were the same. Now, i'm lost as to what could be causing it? Have i skipped a tooth in the timing belt? But then how did it start and idle fine? |
For what it's worth, I've been off by a tooth when installing a t-belt on an H4 and it idled fine but would break up when revved. Honestly, it sounds more like a crank or cam position sensor to me with the hard limit.
1992 SVX LS-L : King of the Stable LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors 1993 Legacy sedan : winter beater, supposedly. 1994 Legacy wagon : future drift car? 1995 Impreza coupe : EZ30++, daily racecar. 1997 Legacy GT : date night rocket? 2003 WRX : future winter beater |
Yes, that's also where my head at when trying to come up with possible causes. Can excessive cranking cause the belt to jump? I guess i'll find out when i take those timing belt covers off.
Tags |
crank, issue, sensors, start |
Thread Tools | |
Display Modes | |
