how do i switch the temp readout to celcius?
just wondering........
i am only assuming there is a magic combination of holding/pushing buttons to swap the reading from farenheit to celcius...........? rob"i wish ONE of my svx came with the owners manual!!"m.
i'm too svxy for my car rob 92 ebony 4.44's rock !! |
There is a connector behind the drivers side kick panel, the one under the fuse panel. The same panel you remove to get to the diagnostic connectors.
I think it's a white connector with one wire, maybe two??? I also don't remember which is which, but I think unplugged will give F, and plugged will give C????
Remove the kick panel on the left side of the car.
Locate a white electrical connector with a SINGLE black wire going into both sides. Pull apart the white connector. Put the panel back on, start the car and turn on your climate control. The temperature is now reading in Celsius! .
Connected: Fahrenheit Disconnected: Celsius .
Thanks John, I had a feeling you'd help clarify my cloudy memory
thank you kind folks!!
rob"jeez, you'd think subaru would do things easier than THAT!.....oh wait who am i kidding!!"m.
