Old 05-11-2015, 07:38 PM
Huskymaniac's Avatar
Uses the ignore feature
Looks like a headgasket issue...
...on the Tribeca.
Wife came home and the car was "making a funny noise". I came out and heard a hissing noise. That's not good. Saw a liquid pooling under the car. That's not good. I thought I smelled coolant. Ugh. Then I dipped my finger in the liquid and it was oily. WTF? Popped the hood. Overflow tank looked normal for level. Checked the dipstick. Definitely lost a little oil. Level was halfway between L and H. Looked under the car and it looked like the leak was coming from near the oil filter. Popped off the cover and looked up there with my scope. The oil filter and sandwich style oil cooler looked clean. I couldn't see where the leak was. Temp gauge had definitely gone above midway but CEL was off. Checked the coolant in the overflow tank and it looks like watered down Cola.
I am assuming the headgasket. But why didn't the overflow tank overflow? And why did I get the hissing from under the engine? Could the oil cooler have sprung a leak? Could something worse than a headgasket have failed? I heard no other unusual noises when the engine was running nor did I see anything on the dipstick other than honey colored oil.
Tony
Old 05-11-2015, 09:37 PM
Re: Looks like a headgasket issue...
hopefully your dark coolant and the leak are unrelated. i have seen the small hoses that go to the oil coolers leak, sometimes only when under pressure. it creates a clean spot because the coolant cleans gunk off your engine and makes it oily. it would be unusual to have an internal and external head gasket leak if you had no previous signs of trouble. overflow reservoirs don't need to overflow if the coolant has another place to go, or you are not that hot.
you can test for a head gasket internal leak with this for $30 or less.
an external leak you will just have to run it and watch for leaks.
how does the fluid in the radiator look?
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 05-11-2015, 09:58 PM
I didn't extract coolant from the radiator but i did wipe the inside of the neck and it was slippery.
Tony
Old 05-11-2015, 10:01 PM
coolant usually feels slippery. oil and water don't mix well so oil will usually be separated from the coolant to some degree. once it gets mixed it looks like a chocolate milkshake.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 05-12-2015, 10:50 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
What do you have coming out the exhaust...any white smoke or sweet smell of coolant? I've found putting the overflow hose in a container of water will show bubbles with an internal leak since you can leave the cap on and system
Old 05-12-2015, 05:06 PM
Didn't check the exhaust but I don't recall anything unusual. It is at my mechanic's place now.
Tony
Old 06-02-2015, 06:35 AM
It turned out that it was only a burst hose. The slippery feel was not oil after all. Sometimes we get lucky. The money ended up going toward a new clutch for the Acura.
Tony
