Old 03-04-2009, 06:20 PM
Exhaust Donuts
My exhaust is leaking . The front 2 and one rear gasket on the CAT are falling apart. Do I need to replace every thing? ( Springs ,bolts , flanges and of course gaskets ) to do this repair. Where is the best place to get SVX parts?
Old 03-04-2009, 06:33 PM
AFBeefcake's Avatar
Subaru Swapper
Re: Exhaust Donuts
Hopefully your flanges are still OK, but you'll need new bolts, nuts and the donuts. You can reuse the springs, but the bolts most like will need to be cut.
I ordered mine from https://www.subarugenuineparts.com/oe_parts_cat.html
2005 Legacy GT
My WRX's Cardomain Page
Old 03-04-2009, 07:25 PM
Re: Exhaust Donuts
If you know someone with dies, have the bolts re-threaded. Worked great for mine and saves a few bucks.
Old 03-05-2009, 02:23 PM
Exhaust Donuts
Where can I get parts for this. Looks I will need new springs ,bolts nuts and gaskets for front 2 and 1 rear of the CAT....on my 1992
Car parts store say they can't get any of this stuff. Is there a cross ref to another Subarru? Or another Car.
Old 03-05-2009, 02:26 PM
Re: Exhaust Donuts
mmm donuts...
usually parts guide refer to them as exhaust packings.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-05-2009, 02:33 PM
Re: Exhaust Donuts
We are cutting them off. Rusted beyond repair. Springs may be savable.
Old 03-05-2009, 02:34 PM
Re: Exhaust Donuts
That is worth a try. Subaru wanted $26.00 each
Old 03-05-2009, 04:25 PM
Re: Exhaust Donuts
Subaruparts.com
part number 8 on diagram-Exhaust gasket (2) 15.90 each part #44022PA021
part number 15 on diagram Bolt (4) 2.98 each part #44059AA010
part number 16 on diagram Springs (4) 6.90 each part #44028PA000
part number 17 on diagram Nut (4) 0.53 each part #902350004
This is for the spring bolt setup for the front of the 2-1 cat. If there's anything else you need, subaruparts.com has excellent diagrams to see parts. Just create an account with your email and password and don't worry, they do not spam.
For the rear of the 2-1 cat
part number 10 on diagram Exhaust Gasket (1) 16.84 part #44022PA031 and you will need 2 each of the spring/bolt/nut from above
Old 03-05-2009, 07:12 PM
Re: Exhaust Donuts
I went to subaruparts.com they don't list SVX . Where did u find that ??
Old 03-05-2009, 07:39 PM
Re: Exhaust Donuts
Here it is. http://www.subaruparts.com/parts.php
It's under number 2 Part Lookup.You'll have to set up an account to access the info.
Old 03-05-2009, 07:44 PM
scottsvx's Avatar
scottsvx scottsvx is offline
f'n a cotton, f'n a...
Re: Exhaust Donuts
From the homepage go to the Subaru tab. Then go to 'Browse our OEM Part catalog' near the top, go down to '2) Part Lookup' and there is a svx link.
Old 03-05-2009, 08:12 PM
stiguy's Avatar
stiguy stiguy is offline
Re: Exhaust Donuts
i just got mine on subaruparts.com just the bolt only think 2 bucks ea. dealer wanted 8
Old 03-05-2009, 11:42 PM
Re: Exhaust Donuts
I merged the two threads together. There were two posts that were the same.
Old 03-06-2009, 08:08 AM
AFBeefcake's Avatar
Subaru Swapper
Re: Exhaust Donuts
If you had a good donut you could take it to like napa and have them try to mach it for you. or bring the cat with you and measer the out side of the pipe that the donut sits on. I think I am using ones from napa on my car. I mite even have the part number. I'll look when I get home.
Also I have tryed the spring and bolt kit for a impreza/legacy from napa, they don't fit. I am just using bolts from the hardware store and springs from the impreza/legacy kit.
2005 Legacy GT
Old 03-06-2009, 09:54 AM
Re: Exhaust Donuts
Next question: Why springs anyway. Was planing on getting stainless nuts and bolts at a hardware store. What size? Length and dia. etc do I need ? they look 5/16 -18 to me and about 2 1/2" to 3" long. Found donuts at Parts America but only front one $16.00 each
